FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Jun 13, 2017 at 11:19 AM Post #17,326 of 18,019
Hi there, I'm new here. Out of curiosity I have some question,
1) I'm using a root X7 with Tidal, so does rooting the X7 cause the X7 to bypass the ES9018S dac, so the audio is process by some internal low quality dac maybe? Is this true for FW3.3.0?
2) I read somewhere, it says that rooting X7 also cause the player to not able to playback at the highest quality for example 192khz, 24bit sample rate due to how Android audio driver is coded. Is this true for FW3.3.0 or does that happen only on FW2.0? Found the link
Jun 13, 2017 at 1:53 PM Post #17,327 of 18,019
My understanding is that X7's ESS DAC cannot be bypassed as there is no other DAC, so even though you're using root with it, you should be enjoying its full audio quality!
Jun 14, 2017 at 4:04 AM Post #17,328 of 18,019
I agree! The FIIO X7 / AM3 balanced is my go-to DAP and feel it a great match for my 64 Audio A12 CIEM's.
Hi, yes, I'm hearing X7 balanced since AM3 was released. Actually AM3 never left X7 since then
A couple of days ago I did a A/B comparison between my X7 and X5 3rd (bal) and liked X7 better (to match volume I had to dial +8 clicks on X5), so I'm curious about X7 2nd specs and mostly about DAC since the amp section seems to be compatible...
Regards
Jun 14, 2017 at 1:05 PM Post #17,329 of 18,019
Regards
I hope it's the ess9018 as this DAC is a big part of what gives the X7 it's great sound.
Jun 14, 2017 at 6:07 PM Post #17,331 of 18,019
Jun 15, 2017 at 2:52 AM Post #17,333 of 18,019
or maybe the new dac used in ak ultima
I believe the A&K Ultima uses two AKM 4497 DACs -- same as my Cowon Plenue 2. Seems unlikely that Fiio will use DAC from same family as X5iii for the X7mkII. More likely a Sabre 9028/38 to create clear product differentiation.
Jun 15, 2017 at 4:51 AM Post #17,334 of 18,019
I really like the sound from the Sabre 9018. An upgrade on that family, dual slot and a volume wheel... that would be nice...
Jun 16, 2017 at 10:28 AM Post #17,340 of 18,019
I just read the mkII might be announced on my birthday (july 16)....so...i think I will wait for that.
wait for mkii, u can hunt down amp modules though as they work with mkii as well
