FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Apr 23, 2017 at 10:07 AM Post #17,221 of 18,019
I'm getting a lot of popping noises with the X7 using UAPP with USB tweak 1 selected. Any suggestions?
That was back in FW2.0. UAPP becomes somewhat glitchy after beta firmware (3.0+).
Try also select 'Force 1 packet per transfer'
Apr 23, 2017 at 9:51 PM Post #17,222 of 18,019
I can not get X5iii to start. Was having trouble with unit so put it in shutdown mode, which took about 5 minutes. Power button is lit blue but unit will not start up, no matter how long I push on power button. Nothing I found in a google search works.
Appreciate any help. Thx.
Apr 23, 2017 at 10:54 PM Post #17,224 of 18,019
  Are DST files supported by the X7? If not, is that something that could be enabled in a future firmware?
Dear betoquiroga,
Sorry, the DST files are not supported by the FiiO Music in the X7: http://fiio.net/en/story/266. We will try to have a look in the future.
Best regards
Apr 23, 2017 at 10:56 PM Post #17,225 of 18,019
Dear FritzL,
Sorry to hear about that. We will send PM to you for more detail soon.
Best regards
Apr 25, 2017 at 7:29 AM Post #17,226 of 18,019
Streaming Tidal is not very good with the latest beta.  Not sure if it's a wifi issue or buffering issue.  When playing tidal the music will stutter, stop or play extremely slow.  Pressing the back button usually fixes it but sometimes it takes a few times before it fixes it.  Which makes me think it's a buffering issue.  I had this problem on previous beta's but only once in a while.  Now it happens on just about every song.
Same
Apr 25, 2017 at 9:21 AM Post #17,227 of 18,019
I'm not having any problems with Tidal version 1.14.0.686.5.
Apr 28, 2017 at 6:37 AM Post #17,230 of 18,019
Apr 28, 2017 at 11:48 PM Post #17,232 of 18,019
Hi guys
I'm thinking of buying Sennheiser HD 600. I have doubt if the following combos can drive it:
- Fiio X7 + AM5 Module;
- Fiio E17k + Fiio K5;
I got this info, but I dont know how to interpret correctly:
* Fiio AM5 module: Output into 300 ohms: >55 mW (300Ω/1 kHz)
* Fiio K5 Max Output Power @ 300 ohm: >150 mW
The AM5 module provides 3 times less power than the K5. Would that be enough?
Thanks a lot for the help
May 2, 2017 at 2:49 AM Post #17,235 of 18,019
Hi Fiio, thanks for the 3.2.1fw, but rewinding and fast forwarding in dlna still not working, also no internet radio streams over the dlna in fiio music player, i get the message: Network unavailable, please try again later, thanks
Dear rusnak666,
What's the software you are using the DLNA with? You may use windows media player/ foobar to see if it helps? If you don't mind, please try another 3rd party APP for help as well. Sorry for bringing inconvenience to you.
Best regards
