FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Apr 17, 2017 at 12:27 PM Post #17,191 of 18,020
New X7 isn't fix software bugs of existing because of the same code base. As for me - this is just waste waiting. They should fix on firmware and not on marketing things.
A new X7 might be based on a different CPU which has different set of instructions thus never having the same problems as the actual X7
Always look at life with positivism!
Apr 17, 2017 at 1:10 PM Post #17,192 of 18,020
we can only hope for some known ARM architecture...
Apr 17, 2017 at 9:56 PM Post #17,194 of 18,020
I have a little issue with Tidal and I'm wondering if any others have encountered the same problem...
When playing Tidal via the am3's balanced output, if I unplug the headphones, and then plug them in again, there's a pretty loud wifi/interference-type noise (much louder than the typical RFI noise when streaming). It goes away instantly when you hit play (even if you instantly pause playback again). Anybody else had this experience??
i use tidal with the am3 balanced out
i couldn't reproduce any issue like that
it may be some kind of local interference
Apr 18, 2017 at 6:31 PM Post #17,198 of 18,020
Just got rudely 'un-zenned' when the 'repeat single track' function failed to work and played a guitar heavy piece after playing a very nice ambient piece.
Of course it now does work on this piece...
Furthermore the new lockscreen sometimes doesn't update after hours of the player being paused.
Lastly, i'm happy i took out the Bluetooth/WiFi module. Apart from distortion while charging it's way more silent, and bass has really increased. (Still hoping for objective measurements by somebody here)
Apr 19, 2017 at 12:55 PM Post #17,200 of 18,020
  There's a new beta out for anyone interested.
http://www.fiio.me/forum.php?mod=viewthread&tid=42269&extra=page%3D1
thanks!
here's a direct link:
http://x7pack.fiio.net/X7-beta-3.2.0.zip
the link in the OP is wrong.
Apr 19, 2017 at 2:00 PM Post #17,201 of 18,020
The DoP functionality still isn't working under 3.2.0, at least with Mojo.
It's funny because there is a DoP/D2P switch in the settings.
Apr 19, 2017 at 11:27 PM Post #17,203 of 18,020
thanks!
Dear CH23,
Yes, the downloaded link was wrong. We have corrected it now. Sorry if bringing inconvenience. BTW, how do you feel of the downloading speed from the link you mentioned?
Best regards
Apr 19, 2017 at 11:28 PM Post #17,204 of 18,020
Dear tomwoo,
We tested in Mojo and works well. What's the sampling rate of your DSD file? Are you using the coaxial output?
Best regards
Apr 20, 2017 at 3:00 AM Post #17,205 of 18,020
  Dear CH23,
Best regards
I noticed that it was really fast!
