Sound Eq
- Nov 9, 2013
@FiiO any news about the bass amp module that was promised to be released
The beta firmware version FW3.1.2_beta for the X7(Android 5.1) is now available!
Kindly note that this is a beta version and might not be stable enough compared to the stable versions. So please think carefully before upgrading with this firmware.
If you have already upgraded the X7's firwmare to the FW3.0beta or a later version, you can download the OTA firmware package, transfer it to the X7 or micro SD card, and upgrade manually through the Technical support app on the X7.
Download link: https://www.dropbox.com/s/f7yrzhv3hmo34jx/X7-3.1.2.170106_beta_b52.zip?dl=0
>>[size=small]How to upgrade[/size][size=small] [/size] (see method 2: Manual update via update zip file)
You can post in this thread if you have any issues with this version. But if you encounter serious problems, you may consider flashing back to a stable release.
Download link for stable firmware FW2.0: [size=small]X7 Firmware Upgrade Tool with FW2.0 (>>backup download link)[/size][size=small] [/size]
The following improvements and changes have been made to the FW3.1.2beta compared to the FW3.1.1beta:
1. Added case-insensitive search function;
2. Fixed issue where some multi-channel tracks would be played abnormally;
3. Fixed issue where some WMA tracks would be played abnormally;
4. Fixed issue where the Covolver option in ViPER Effect would not work;
5. Fixed issue where FiiO Music would exit abnormally when playing some .m4a tracks;
6. Fixed issue where the album art display in the FiiO Music main menu would not change when swiping it to change tracks;
7. Fixed issue where when playing the Favorites/playlists, the order of the list will change after re-entering the Now Playing menu;
8.Fixed issue where the sound would only output through one channel when playing a mono track;
9. Fixed issue where the lyrics would not disappear after switching from a track with lyrics to a track without lyrics;
10.Fixed issue where the Gain setting would be reset to Low after restarting the player;
11.Changed the application permission of ES File Manager (now it can be uninstalled);
12.Fixed issue where some null pointers would cause FiiO Music to exit abnormally;
13.Fixed issue where the Android service would stop when using the share function of ES File Manager.
Note:
If it fails to scan the media library, please send the crash folder("internal_sd\FiiOMusic\crash") to us at support@fiio.net.
http://fiio.me/forum.php?mod=viewthread&tid=41887&extra=page%3D1
The English version of above:
Updating to fw3.1.2beta no issue so far with fiio music app
Sadly, not for me...
The app fail to recognize 4/5 of my music (yes, epic fail!).
Just reverted to FW2.0, media scanning works waaaay better and a lot faster!
Also the sound, seem better to me, but i'm not too sure, i need to listen more this night.
It scans all my files and I have embedded art
