harpo1
- Dec 1, 2014
after upgrade to 3.1.12 (and factory reset)
- FiiO Music app crashed numerous times with error and got restarted
- Scanning works intermittently - it didn't work at one attempt - the error was raised during some 3500th song.
After 12 hours and device restart it is scanning much further and it failed around 6000th song.
Error is this:
Error during the random FiiO Music crash is this:
Another error raised during scanning is this:
It just seem you can never get it right..
After executing these commands on the SD Card:
and cleaning the whole card with CleanMyDrive2 software which removes all hidden and junk files and then resetting the whole library database. The scanning still fails on file 6437 with:
Please send me the classes from package com.fiio.music.util and I'll fix it for you. The simplest solution you could use is to enable debug logging and output the file name. That way, once the exception is raised I will know which file is causing the troubles and I could send it to you for inspection. Please propose this to your developers. Thanks.
Please fiio send the man what he needs. I'm sure he'll have the scanning issue fixed in no time.
