Fiio X5iii Custom Kernel and Scripts | 2016MHz CPU | 20% RAM increase | Undervolting | New DAC drivers | and much more
post-15020385
Post #106 of 449
WitzyZed
Forest Park, IL
Forest Park, IL
If app is not successfully installed, you may have to uninstall your existing FiiO Music app, the version # is identical (1.1.0) to that found in OFW 1.2.4., but it is a fix nonetheless.
post-15020564
Post #107 of 449
illi4
Thanks, I will try again, but I have already tried this and the new version of the app did not help unfortunately
post-15022683
Post #108 of 449
lookingforowls
New England
New England
Whats the pause issue you are discussing ?
post-15022874
Post #109 of 449
WitzyZed
Forest Park, IL
Forest Park, IL
When hitting the lock screen / power button, people were saying FiiO music (exclusively?) in Pure Music Mode would pause playback. And it was dependent on the output used too? Like maybe 3.5 headphone output was unaffected, and 2.5mm headphone output was, I know users said line out was. I wasn't able to repeat the issue myself even when it was brought up. But FiiO posted a new(?) .apk of FiiO Music 1.1.0, the same version number that came with firmware 1.2.4. But that fixed the issue for that particular user, and I wasn't able to repeat it again, either.
Context begins here:
https://www.head-fi.org/threads/fii...dual-card-slot.828402/page-1005#post-14996848
post-15023588
Post #110 of 449
illi4
In my case the issue is (both android and pure music, any output):
- Start playback in Fiio music (any version), press pause with the screen shut down
- Wait for more than ~ 30 seconds, press play
- The screen lights on, the music stutters, and the other track starts playing
I have changed all the firmwares and all the kernels and nothing seems to help. Also tried various SD cards and only copying some of my music (not all).
UPD: Tried with OMNIA Music Player - it also lights up the screen after a long pause, but at least it can resume playing the same track. It's a pity that button fast forward doesn't work on it, though
post-15025014
Post #111 of 449
WitzyZed
Forest Park, IL
Forest Park, IL
My X5III has FW (Fidelizer) 1.2.4, custom kernel 3.2, using 1.1.0 apk of FiiO Music shared on the forum, in pure music mode, using 3.5mm headphone output. I had a song playing, I turned off the screen, paused the song, started stopwatch, around 40 seconds I hit play, screen lit up, and within two seconds the song resumed from where it was paused. There was no switching to "other" songs.
post-15027663
Post #112 of 449
jkbuha
Dear Head-Fi community
After weeks of tweaking and optimisation, prispewnic and I are pleased to announce Version 3.3 of the X5iii modded kernel. As can be seen from the changelog below, this release is a pure performance release; ie: tweaks, enhancements and maximum optimisation.
Changelog
Version 3.3
New: Enabled ARM ARCH_POWER feature
New: Disabled Gentle_Fair_Sleepers (much faster)
New: Enabled cache wakeup preemption
New: Forced memory overcommit for better performance
New: Ignore all ICMP echo requests
New: Enable TCP low latency
New: Removed noatime and nodiratime to improve ext4 and sys filesystem performance (much faster)
New: Added asynchronous filesystem calls (much faster)
New: Enable TCP reuse read mostly algorithm
New: Enable TCP sysctl recycle algorithm
New: Disable TCP slow start after idle
Enhanced: Optimised SLUB memory allocator
Enhanced: Reduced Mini Memory Map to from 32k to 0
Enhanced: Reduced Max Block Dev size from 128 to 32
Enhanced: Increased Max Queue length from 128 to 1024
Enhanced: Tuned kernel fair scheduler workload parameters
Enhanced: Increased memory threshold compaction from 500 to 800
Enhanced: Reduced dirty write back interval
Enhanced: Increased sysctl read interval for reduced latency
Enhanced: Optimise TCP sack/fack/dsack read requests
Enhanced: Optimise TCP memory pressure
Enhanced: Optimise TCP proto packet length algorithm
Enhanced: Added options for disabling and restoring stock player FiiO Music
Fix: Minor AROMA Bugfixes
Download and install as usual from the following link:
http://bit.ly/FiiOX5iiiV33
Thanks and Rants
Again, massive thanks to prispewnic's product features, suggestions and testing, and the great community of beta testers on Head-Fi and 4PDA.
Thanks also to @FiiO for releasing the first GPL of the source code back in June - now waiting on you to help us support the X7/M11 in the same way as the X5.
As always, any queries, comments etc - please shout.
post-15027758
Post #113 of 449
MinnieOne
Updated just now and for some reason it shows 3.2 kernal optimization message. Also in setting it shows me "Tue May 28 13:29:52 BST 2019".
I know I did the update because I selected the auto load to Power Amp for the first time I've used that and that worked fine, so what could have gone wrong here?
NEVER MIND, I realized I had the leave previous Kernel check box on.
post-15029437
Post #115 of 449
Focalor
Lisboa, Portugal
Lisboa, Portugal
Hi,
I had the same issue several times and is not "fiio music" related but rather firmware update related.
I Did the following to resolve the issue:
  • Find FiioMusic folder via ES Explorer and remove folder
  • Go to TWRP and Clean Cache and Dalvik.
  • Reboot and reconfigure FiioMusic app
Hope this help you resolve your issue :)
post-15029822
Post #116 of 449
nekromantik
im not finding this firmware to be stable.
2 or 3 times out of 5 when turning on the device it gets suck on the fiio boot logo and then turns off after a few mins.
Only way to get it to boot is recovery mode and flash old kernel
Reactions: MacPac
post-15029885
Post #117 of 449
WitzyZed
Forest Park, IL
Forest Park, IL
The kernel hasn’t been unstable or causing any boot problems for me. Of the ten or more times I’ve turned this thing on since yesterday morning, not one time did it hang on booting.
Reactions: eddy1963
post-15030017
Post #118 of 449
MacPac
+1
Only boot first time... then any reeboot freeze in "welcome" boot logo and then go off after few time
Now on v3.2 again (no problem with 3.2)
post-15030121
Post #119 of 449
nekromantik
+1
glad its not only me!
I used same settings in aroma as 3.2 also nothing changed
post-15030177
Post #120 of 449
SteveUK
And another one here - same symptoms. I finally installed 3.3 with the lower speed version rather than balanced that I'd used with 3.2 and it seems ok now.
