Fiio X5iii Custom Kernel and Scripts | 2016MHz CPU | 20% RAM increase | Undervolting | New DAC drivers | and much more
post-15037363
Post #152 of 449
MinnieOne
Does the speed setting effect battery life in any way?
post-15038060
Post #154 of 449
WitzyZed
Forest Park, IL
Forest Park, IL
with the way the kernel & cpu governer so so smartly keeps half of the cores offline (watch this in kernel adiutor) until interaction with the screen is detected, I would still say your battery usage is still mostly impacted by WiFi/Bluetooth status, screen brightness, auto lock timers and power off timers. you’ll see a % in kernel adiutor where the cpus spend most of their time at, usually I find 504 MHz and 1416 MHz being the most utilized.
post-15038386
Post #155 of 449
jkbuha
That's the power of the new interactiveX governor with AutoSMP CPU hotplug. Not dissimilar to the way modern (petrol) engines shut down half the pistons when revs are low/idling. With this mechanism a tuned 2016MHz player will outperform a vanilla 1416MHz player on battery life, same app usage notwithstanding.
For a proper scientific comparison, I'd always advocate benchmarking using root-enabled battery apps such as BetterBatteryStats. They can give you a better view of which app (or kernel process) is contributing to so-called wakelocks. Most android apps are quite sloppy in this regard; keep the CPU awake unnecessarily and rely on the kernel to clean up the mess...
post-15038622
Post #156 of 449
etoilebiscuit
if my fiio x5iii keep hanging at 2016mhz cpu after i install, does it mean its not compatible? after it reboots, it get starts at fiio loading screen.
post-15038847
Post #157 of 449
jkbuha
Unfortunately, yes. Start with the 1704MHz build as that works on 90% of players. If that fails as well, then use the 1416MHz version.
post-15039775
Post #158 of 449
Bray90820
I may or may not be having an issue I installed Version 3.3 today and the date changed but the build number still is telling me I am on 3.0.101
post-15039790
Post #159 of 449
WitzyZed
Forest Park, IL
Forest Park, IL
Nah you’re good! Totally different “version” that’s being referred to there. If you saw that kernel version on stock you’d also see 3.0 yadayadayada. It was less of a confusion in earlier versions of the kernel. Once it got past the 3 mark it’s easy to understand how.
post-15039792
Post #160 of 449
WitzyZed
Forest Park, IL
Forest Park, IL
If you get kernel optimization prompts and the date is current, you’re fine :)
post-15039798
Post #161 of 449
Bray90820
Thanks
post-15040176
Post #162 of 449
nekromantik
Had new issue.
While playing music via fiio player the music suddenly stopped and screen or buttons not responding. Had to hard restart.
post-15040251
Post #163 of 449
Powderphinger
Midwest, US
Midwest, US
Had new issue.
I had something similar happen with the FIIO player. However, it's their beta version and frankly, I just attributed to it being a FIIO product rather than an issue with the kernel. I've been using UAPP and it's been working like a champ. I'm close to deleting FIIO's music player.
McHoop
post-15040592
Post #164 of 449
nekromantik
McHoop
would love to delete it but only other app I like is neutron but for some reason my x5 just dont like it. after a few songs it closes itselff
others solved issues by re install but mine persists
post-15042337
Post #165 of 449
Ghost Of Lundy
Barboursville
Barboursville
Try deleting Fiio music player. I did and it fixed the neutron issue where it crashes. . At least for me. You can always flash the original firmware if it didn’t work.
