nekromantik
- Jul 30, 2009
I dont know if this message has any sense for anyone - except yaslam - my thanks to him, but if anyone is
interested in Neutron improved for our Fiio X5.... from the conv - maybe in few days /hopefuly/ will send another test version of Neutron player...
Thank you very much for testing! It looks that new driver performs
well on X5 too.
**Neutron**
DSD128 and 256 are quite expensive for CPU and memory bus for
conversion to PCM and thus underruns may occur.
In nearest updates Neutron will be able to send DSD directly to the
Fiio's DAC (iBasso too) and thus problem will be solved. Work on a new
implementation of Neutron's driver appeared to be too hard to include
DSD in it. Next release will feature new driver and new hi-res
capabilities on some mobile devices which support offload and direct
PCM scenarios and then DSD will be added too. Some mobile devices
support offloaded DSD format too so it will be useful not only for
DAPs.
By the way does Neutron show > than 192 kHz in the frequency list
inside Audio Hardware -> Frequency (when Follow Source Frequency is
switched off)? If 192 kHz is a max and Fiio is sure that device can
play with 352.8 kHz and 384 kHz then these frequencies should be
exposed via AudioTrack::getMinBufferSize() because Neutron tests
frequency availability up to 768 kHz.
By the way hi-res test files can be found here:
http://www.2l.no/hires, there 24-bit/352.8 kHz files for testing.
Best regards,
Dmitry.
Good news from them.
I purchased it and will keep eye out on here. Please do post test build.
