superuser1
Did you find a nice short cable for that?X5iii coax out to ifi dsd black label to any earphone or headphone is the bomb
Yikes, really ? Take a pic bro. You using that cable that came with the X5III ?X5iii coax out to ifi dsd black label to any earphone or headphone is the bomb
i have the same one and i look like the hangman walking around with that thing hanging from the stackI found a fiio one but it is a metre in length. Fiio L21
Yes for desktop use it is fine...good actually. But the size of the iDSD and the cable issue makes it impractical (for me) to use as a portable solution.X5iii coax out to ifi dsd black label to any earphone or headphone is the bomb
3 hrs a day on the go with it.Yes for desktop use it is fine...good actually. But the size of the iDSD and the cable issue makes it impractical (for me) to use as a portable solution.
Ha, around here everybody keeps to their phones.Not sure it's the greatest of ideas to walk around with something like that hanging out of your pocket with the state of the world right now.
Ha, I walk in 35c, get on many trains and buses with it plus I carry a back pack with four to six Basket balls. I usually stand but if I do get lucky to sit I can just hold it. If I have agorts on no problem. I also use the Hugo on the go if theres a will theres a wayWouldn't work for me with my build and use pattern. Sitting would be quite uncomfortable. I also tend to catch IEM cables or headphone cables on every available obstruction if they are not coiled, kept short, and clipped to my shirt.
I have considered a shoulder bag, but that is just something else to get in the way. I do like the Black Label though. But I think it is more designed to be transportable versus truly portable.
It is quite nice that I can use the X5III as a transport with it. This points to some kind of compatibility issues with the Mojo.
Seriously considering an X5 Mk3 on ebay UK. There are some open box models from a company stating opened but not used, which I always find suspicious and are probably returns, but someone selling a brand new sealed unit at £330. So tempting.
I just looked at the units you are quoting and I see that they are from AdvancedMP3. I have purchased a number of items from them including my x5II and X5III and I have found them to be honest and reliable. My last X5III failed after 4 months and they exchanged it straight away without quibble with next day delivery through Amazon.
