A new and more reliable way of using the X5 3rd gen stacking kit.
Do sobgs cut out and glitch before they stop playing altogether? Do the songs disappear the moment you check the card? It's happening on mine and I can't seem to fix it. Tried nearly everything.
Should I go back to the previous firmware update?
I've had that happen once or twice. I now have issues powering down the unit or rebooting. I simply get the message that it is doing either, and 15 minutes later... it is still trying to do that same function. If I hold the power button down to force it to shut down, it reboots. I've contacted Fiio for a replacement unit, personally... I wish I could just get a refund.
Did you try using the DAP without any cards to see if the problem persists?I've had that happen once or twice. I now have issues powering down the unit or rebooting. I simply get the message that it is doing either, and 15 minutes later... it is still trying to do that same function. If I hold the power button down to force it to shut down, it reboots. I've contacted Fiio for a replacement unit, personally... I wish I could just get a refund.
I am on 1.1.7 and though gapless is not working i seem to be able to browse through the folders inside Fiio Music while its playing.Haven't had too many issues with mines but latest firmware has introduced a bug where if I start looking into my folders for an album while music is playing, it will boot me out all together on occasion. Didn't have this issue with previous firmwares. Anyone else have this issue? Not a big deal as the music just stops playing and I have to start looking from opening fiio music app again but kind of annoying.
