2. Playback Gain Control :
It is mainly used to dynamically control the audiovolume, to amplify or to attenuate.
(1) Enable checkbox : Whether the effect is enabled.
(2) Select Effect Strength : Effect Strength is the speed of amplification or attenuation, the stronger the faster the speed and the higher the final volume, the weaker the slower the speed, the closer to the original volume. Recommended medium.
(3) Max Gain : When the volume of the note is too small, in order to uplevel the sound, there may be very large magnification. The higher the value, the louder the volume. But too large will also amplify the noise within the song. Recommended 4 times.
(4) Max Output : This value defines the maximum volume of the PlaybackAGC sound in decibel value, the greater the value the greater the volume, 0 db is the maximum. In order to make the sound softer recommended -1.9 dB.
