Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
Aug 20, 2017 at 5:35 PM Post #10,982 of 15,897
My question is it possible to change icons with customized theme icons like you can on android devices.
i like Fiio X5 III a lot but i prefer not to have the default look of fiio icons, i like Neon Black and Red icons on a black background.
I always mod the mobiles to customize icons and docks so it look like i want it.
Is it possible on Fiio X5 III, this is what i want to do design and good sound.
Aug 21, 2017 at 5:12 AM Post #10,983 of 15,897
Can we get a fix in the next update that makes the player interact better with 256 GB cards?
Aug 21, 2017 at 5:31 AM Post #10,984 of 15,897
@FiiO
for the next update, could you please fix/translate the message in chinese that appears when adding a song to the favourites ? (press the heart icon and you get a message in chinese), i suppose it means "added to favorite" or something close but it would be nice to have it in english :)
thanks
Aug 21, 2017 at 5:52 AM Post #10,985 of 15,897
Thanks for the reply. I have emailed support several times with no reply. The headphone icon does display, even if the headphone or line out jacks have nothing plugged into them.
Dear friend,
Could you please PM us your email address? We will send PM to you about that later.
Best regards
Aug 21, 2017 at 5:58 AM Post #10,986 of 15,897
@FiiO
thanks
:disappointed_relieved:Dear friend,
Which one? Would you mind a screenshoot? Thank you in advanced!
Best regards
Aug 21, 2017 at 7:10 AM Post #10,987 of 15,897
Best regards
Sure, so i press the menu buttton then the "heart" icon (to add to favorite) :
then i get this message :
Aug 21, 2017 at 11:25 AM Post #10,988 of 15,897
OK. Done some listening comparrisons between my HA2SE & X5III.
Same tracks with Shute SE846.
For many tracks they are vary comparable just with slightly different sound signature.
One piece made me decide I prefer the X5III, Candido - Arcason which has lots of instruments and vocals spread across an open sound stage.
X5III sounds more 3D with greater soundstage and positioning, instrument separation better defined with greater air between singers and instruments. It feels as if I'm more in the room with the artists than on the HA-2SE.
If I had to sell one today it would be the Oppo as the X5III is least as good if not better than the Oppo and far more practicle as a single device.
Now going to do some testing with balanced cable now.
X5III has more backround hiss than HA2SE but only noticeable netween tracks in a totally quiet room and thats with super sensitive SE846's.
The X5III is also far better value than a HA-2SE.
Sent from my SM-G930F using Tapatalk
Thanks a lot for this comparison I was undecided on whether to buy HA-2SE or Fiio X5 gen 3 , looks like X5 is more practical and better sounding than HA-2SE
Aug 21, 2017 at 2:26 PM Post #10,989 of 15,897
I've set the time to use the 12 hour format; however, on the fiio music screen that appears after no activity (not sure what to call it) it still shows up using the 24 hour format. Am missing something?
Also, FIIO any news on the implementation of replaygain and a new sorting methodology? Also, is support of multiple tags possible?
Aug 21, 2017 at 3:07 PM Post #10,990 of 15,897
I believe the lock screen is controlled by Android and not FIIO. If you figure out how to change it, let us know because it bugs me as well.
Aug 21, 2017 at 5:01 PM Post #10,991 of 15,897
Is the latest firmware still 1.1.7? I have 12hr format on lock screen. Unless I have no clue what you guys are talking about... which could be... I'm playing with Krylon Kamar Varnish on some "wood" plugs I'm making for a cable... so I'm a little bit loopsy.
Aug 21, 2017 at 5:20 PM Post #10,992 of 15,897
Seems to be more than one lock screen on this device, sometimes you get a correct clock and other times when it locks while music playing you get this one.
Aug 21, 2017 at 5:22 PM Post #10,993 of 15,897
Go to Settings > Date & Time > Use 24 Hour Format > Toggle On/Off.
On my Fiio X5iii the lock screen shows whichever format has been selected, even the lock screen in Fiio Music.
Hope this helps!
