New Fiio Owner
My Macbook has USB 3.0 ports and the Fiio X5iii connects and is recognised by the laptop.
Like you, however, I had problems connecting at first. The following replies from Fiio might be of help:
1. If you want to make the X5III work as a DAC, you should change the Storage mode to DAC mode firstly.
While in Android mode, please pull down the settings menu from the upper of the X5III's touch screen and click on "Storage" icon, then it will be changed to "USB DAC".
2. But if the X5III is set to Storage mode, it will not work?
When running Storage mode, if you connect the unit with the computer via USB, the "USB mass storage interface" will show up on the touchscreen, and you will be required to click "TURN ON USB STORAGE" on the X5III's screen.
No, this is a long term issue. I raised it about 4 months ago, it was confirmed by other users on here especially those with Surface Books who only have one port.
It seems to be a problem with newer laptops or specific controllers. I thought I had found a work around by connecting it to my USB C port via an adapter, but that stopped working after my computer upgraded to Windows Creator and Fiio updated the ROM.
The only way that I can manage music now is by removing the SD Cards, but this does not help me with the internal memory.
