ctruth
- Apr 15, 2016
Whoa! The Mark III is already out????
OOps. No. Fixed. TY
Darn, I had my wallet out.
Those on FW 1.1.7, does uninstalling google service framework affect usability and update-ability of Spotify?
Anyone else using that test versoion of neutron get random times when after a song is finished it closes itself?
For example it did this 3rd time in a row and when you look at lockscreen it shows the neutron info and track it played but after you unlock it goes to home screen and neutron is no longer running.
i dont have that issue... i hope the neutron guys are cooking something.... no new message from yesterday... hope the people FROM FIIO SEE THIS, hear us and dont overlook all this... i post here if any new message will come from Neutron...
Its quite annoying bug. It was clean install.
I will try updating to latest test fw.
and the X7 Mark II does not have “Dual AKM AK4490EN DACs”
$649.99. For what?
If it wasn’t for the wonderful sound of my X5 3rd gen with the Dual AKM AK4490EN DACs, I would abandon it, in a New York minute….
This is a ridiculous long term issue. Why is it that the old X5II will connect with USB 3.0 but this new X5III will not?
Neutron's log file did not seem to contain the correct log. (You also need to create a logs folder)
Therefore, this is the debug log of Android Studio.
Also, neutron's 32 bit output setting had to be invalidated.
- FLAC 24bit/192kHz : working (24_192_flac.txt)
- FLAC 24bit/352.8kHz: not working (24_352.8_flac.txt, error log: 352800 Hz is not a supported sample rate)
- WAV 24bit/192kHz : working (24_192_wav.txt)
- WAV float32bit/192kHz : working (float32_192_wav.txt)
- WAV int32bit/192kHz : working (int32_192_wav.txt)
- DSD64 : DoP playback with noise (dsd64.txt)
- DSD128: DoP not working (dsd128.txt, error log: 352800 Hz is not a supported sample rate)
The following is the log of FiiO Music.
FLAC 24bit/352.8kHz can be played. It seems that processing is done as 176.4kHz * 2 from the log.
Audioformat = 10 is not used to play the DSD file.
Audioformat = 7 (ENCODING _ DTS) is set in DSD64.
Audioformat = 8 (ENCODING_DTS_HD) is set in the DSD128.
AudioFormat | Android Developers
https://developer.android.com/reference/android/media/AudioFormat.html
I have not got any information from FiiO about sample rate above 192kHz file and DSD file.
If you want to play these audio formats, I think that you need to confirm details with FiiO.
- FLAC 24bit/352.8kHz: working (24_352.8_flac_fiio_music.txt)
- DSD64 : working (dsd64_fiio_music.txt, audioformat=7 -> ENCODING _DTS)
- DSD128: working (dsd128_fiio_music.txt, audioformat=8 -> ENCODING_DTS_HD)
Edit: insert log file link
