Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
Aug 8, 2017 at 9:18 AM Post #10,741 of 15,899
Thanks for the update. Good to hear that you guys are trying to fix it.
I did contact the guys of RocketPlayer last April and they said it was on their to-do list.
I'll send them your info and hopefully either one of you might figure it out at some point.
Thanks again!
Got this reply from RocketPlayer:
Hi,
Thank you for reaching out.
This is a limitation of Rocket Player. It's only able to display the internal storage and one SD card storage.
Seems like they are not in a rush to fix this... :triportsad:
Aug 8, 2017 at 9:28 AM Post #10,742 of 15,899
Yes, but it does indicate that this is not a fault with the Fiio player. The Neutron testing going on looks interesting though.
Aug 8, 2017 at 9:54 AM Post #10,744 of 15,899
send your log please here...
Dsd - folow freq of the song does not work for me... folow freq works great on high res songs, or flacs... all freq to 192000hz are working for me... dop - i hear music playing very muted and a strange noise like old LP... higher freq then 192000 are not working for me...
latest reply from neutron----
Hi Joseph,
Thank you very much for testing!
> 64/out:8.24/
8.24 is ok! It means 24-bit format in 32-bit containers. It seems that custom 10 encoding works.
Do you see 192 - 384 kHz frequency range also, or only up to 192 kHz in Frequencies?
What about logs folder in NeutronMP? E.g. do you have /NeutronMP/logs created as well?
Best regards,
Dmitry.
which logs ?
I created the folder at the root of the X5 and i got :
- Playlists (empty folder)
- .nomedia
- eq_presets.xml
- neutronmp.db
- streaming.xml
no logs folder
Aug 8, 2017 at 11:02 AM Post #10,747 of 15,899
hm.. try to manually create log folder in neutronmp folder.....play 1 song to the end...look in the log folder... for me was here 2 log files
[17:00:04] I <Log>| Logging started
[17:00:05] I <SFX>| sfxmini: System::Initialize: begin
[17:00:05] I <SFX>| sfxmini: System::Initialize: - load lib
[17:00:05] I <SFX>| sfxmini: loaded library: /data/app/com.neutroncode.mp-2/lib/arm/libiauxsfx.so
[17:00:05] I <SFX>| sfxmini: System::Initialize: - init library
[17:00:05] W <SFX>| android.media.AudioTrack: setPreferredDevice() not found, not API 23
[17:00:05] W <SFX>| android.media.AudioManager: 'AudioDeviceInfo[] getDevices (int flags)' not found, not API 23
[17:00:05] W <SFX>| android.media.AudioDeviceInfo class not found, not API 23
[17:00:05] W <SFX>| JNISFX_CreateEnvironment: AudioDeviceInfo failed to load: AllocClassEnv() failed
[17:00:05] I <SFX>| platform::android::pROPERTY_OUTPUT_FRAMES_PER_BUFFER = 4096 (OS align = 4096)
[17:00:05] I <SFX>| MPEG: loaded
[17:00:05] I <SFX>| MULTI: loaded
[17:00:05] W <SFX>| plugin: directory[/mnt/internal_sd/Android/data/com.neutroncode.mp/plugins] does not exist
[17:00:05] I <SFX>| sfxmini: System::Initialize: - init system
[17:00:05] W <SFX>| CSystem: ignoring start 'StreamUpdater' due to: DEV_SETUP__NO_3D|DEV_SETUP__NO_HW
[17:00:05] I <SFX>| sfxmini: System::InitializeBegin: ok
[17:00:05] I <SFX>| GetHWInfo: channels: 1/8
[17:00:05] I <SFX>| atrack-drv: format 24-bit int
[17:00:05] I <SFX>| atrack-drv: detected Fiio audio hw:
[17:00:05] I <SFX>| atrack-drv: - 44100 Hz
[17:00:05] I <SFX>| atrack-drv: - 48000 Hz
[17:00:05] I <SFX>| atrack-drv: - 88200 Hz
[17:00:05] I <SFX>| atrack-drv: - 96000 Hz
[17:00:05] I <SFX>| atrack-drv: - 176400 Hz
[17:00:05] I <SFX>| atrack-drv: - 192000 Hz
[17:00:05] I <SFX>| atrack-drv: - 352800 Hz
[17:00:05] I <SFX>| atrack-drv: - 384000 Hz
[17:00:05] I <SFX>| ----------------------
[17:00:05] I <SFX>| driver: name | AudioTrack (JNI)
[17:00:05] I <SFX>| driver: index | 0
[17:00:05] I <SFX>| driver: config | 00000002
[17:00:05] I <SFX>| device: channels | 2 [min[1] max[8]]
[17:00:05] I <SFX>| device: bits | 32
[17:00:05] I <SFX>| device: smpl.type | 0
[17:00:05] I <SFX>| device: rate (Hz) | 44100
[17:00:05] I <SFX>| device: min buf | 120416
[17:00:05] I <SFX>| device: latency | 341 [min: 341, max: 1000]
[17:00:05] I <SFX>| device: formats | 00080088
[17:00:05] I <SFX>| device: rates | 00007F80
[17:00:05] I <SFX>| atrack-drv: default device id[0] index[0]
[17:00:05] I <SFX>| driver: name | OpenSL ES
[17:00:05] I <SFX>| driver: config | 00000003
[17:00:05] I <SFX>| device: channels | 2 [min[2] max[2]]
[17:00:05] I <SFX>| device: bits | 16
[17:00:05] I <SFX>| device: rate (Hz) | 48000
[17:00:05] I <SFX>| device: min buf | 65536
[17:00:05] I <SFX>| device: formats | 00080000
[17:00:05] I <SFX>| device: rates | 00000000
[17:00:05] I <SFX>| |usb| found USB device: id[058F:6366] addr[2:19]
[17:00:05] I <SFX>| |usb| found USB device: id[1D6B:0002] addr[2:1]
[17:00:05] I <SFX>| |usb| found USB device: id[1D6B:0002] addr[1:1]
[17:00:05] W <SFX>| query: no USB devices currently found
[17:00:05] I <SFX>| driver: name | FMT<au>
[17:00:05] I <SFX>| device: channels | 8
[17:00:05] I <SFX>| device: latency | 0
[17:00:05] I <SFX>| driver: name | FMT<wav>
[17:00:05] I <SFX>| driver: index | 1
[17:00:05] I <SFX>| driver: name | FMT<speex>
[17:00:05] I <SFX>| driver: index | 2
[17:00:05] I <SFX>| driver: name | FMT<null>
[17:00:05] I <SFX>| driver: index | 3
[17:00:05] I <SFX>| driver: name | FMT<vorbis>
[17:00:05] I <SFX>| driver: index | 4
[17:00:05] I <SFX>| driver: name | FMT<flac>
[17:00:05] I <SFX>| driver: index | 5
[17:00:05] I <SFX>| driver: name | FMT<mpeg>
[17:00:05] I <SFX>| driver: index | 6
[17:00:05] I <SFX>| sfxmini: System: - lookup driver
[17:00:05] I <SFX>| sfxmini: default device: AudioTrack (JNI) - ch[2] sr[44100]
[17:00:05] W <SFX>| sfxmini: requested default device of driver: AudioTrack (JNI) {drv = 12} - ch[2] sr[44100]
[17:00:05] I <SFX>| sfxmini: System: - init backend[0]
[17:00:05] I <SFX>| sfxmini: System: backend - create IMasterMix handle
[17:00:05] I <SFX>| sfxmini: System: backend - fill args
[17:00:05] I <SFX>| sfxmini: System::Initialize: backend - select latency
[17:00:05] I <SFX>| sfxmini: System::Initialize: backend - select granularity
[17:00:05] I <SFX>| sfxmini: System: requested backend:
[17:00:05] I <SFX>| sfxmini: - drv uid | DRV<atrack>
[17:00:05] I <SFX>| sfxmini: - drv index | 0
[17:00:05] I <SFX>| sfxmini: - drv name | -
[17:00:05] I <SFX>| sfxmini: - channels | 2
[17:00:05] I <SFX>| sfxmini: - bits | 32
[17:00:05] I <SFX>| sfxmini: - smpl.type | 0
[17:00:05] I <SFX>| sfxmini: - rate (Hz) | 44100
[17:00:05] I <SFX>| sfxmini: System::Initialize: backend - init master-mixer
[17:00:05] I <SFX>| driver: AudioTrack
[17:00:05] I <SFX>| -------------------------
[17:00:05] I <SFX>| CAndroidOutputDriver | init:
[17:00:05] I <SFX>| device: channels | 2 [1/8]
[17:00:05] I <SFX>| device: sg-latency| 140
[17:00:05] I <SFX>| device: sw-frames | 884
[17:00:05] I <SFX>| device: sw-bytes | 7072
[17:00:05] I <SFX>| HW buffer:
[17:00:05] I <SFX>| device: hw-frames | 6188
[17:00:05] I <SFX>| device: hw-bytes | 49504
[17:00:05] W <SFX>| device: hw-frames | 15912 (corrected against min[120416] bytes)
[17:00:05] W <SFX>| device: hw-bytes | 127296 (corrected against min[120416] bytes)
[17:00:05] I <SFX>| device: sw-latency | 20 ms
[17:00:05] I <SFX>| device: hw-latency | 360 ms
[17:00:05] I <SFX>| CAndroidOutputDriver | done.
[17:00:05] I <SFX>| MasterMix: frames per buffer[884] << ch[2] sr[44100] gr[50000]
[17:00:05] I <SFX>| sfxmini: System: backend - create ISubMix handle
[17:00:05] I <SFX>| sfxmini: System::Initialize: backend - init sub-mixer
[17:00:05] I <SFX>| sfxmini: System::Initialize: backend - link sub-mixer to master-mixer
[17:00:05] I <SFX>| sfxmini: System::Initialize: backend - ok
[17:00:05] I <SFX>| sfxmini: System::InitializeEnd: ok
Aug 8, 2017 at 11:09 AM Post #10,748 of 15,899
Hi,
Interesting. I thought that RP saw both cards on the XDP (which I've had for a year now) and was just a problem with the X5iii (which I just bought a week ago). I went back to the XDP and sure enough the app does only see the one SD card. I guess I'm going to update my Google Play review and deduct a star for this glaring oversight! :frowning2:
Aug 8, 2017 at 11:53 AM Post #10,749 of 15,899
THANKS... I SENDED IT TO NEUTRON WITH MY LOG...
> 32bit output still distorts sound
THE REPLY FROM DEV - ITS A BUG IN FIIO FIRMWARE
Yes, it is a bug on their side but actually 8.24 and 32-bit floating
point will give the same result - max 24 bit depth.
Aug 8, 2017 at 3:00 PM Post #10,751 of 15,899
Dont have time right now, but it seems that i can see now more than 48000hz and to 192000hz it is working, 32 bit still dont work, dop over pcm dont work, folow freq of the sound is clamped to 176000hz... but i am impressed, hopefuly it can be a step forward... please try... you can put the logs here i will send them to neutron... thanks..
Hi,
Here is dev version with 24-bit extended encoding (10) added in
AudioTrack driver:
http://neutronmp.com/download/dev/NeutronMP_NEON_DEV_080817.apk
Would you please check how Neutron works on your device. This extended
encoding is only for AudioTrack API and thus Audio Hardware -> Generic
Driver option must be switched on. If it is not, please switch it on,
confirm changes and re-enter to Audio Hardware settings.
If Neutron detected encoding then:
1) Current format: Bits will show 32 or 64 (out: 24);
2) Frequency section (in the bottom of the list) will have more than
one frequency up to 384 kHz.
If that is available then all is ok.
You could switch on DSD over PCM (DoP) option and try playing some DFF
or DSF files as DoP. It is interesting whether it will work.
Also, this dev version supports logging of SFX core, so that if you
create NeutronMP folder in the root of internal storage (where you see
Android, Music, ...) and logs inside NeutronMP (you will get
/NeutronMP/logs) then Neutron will do logging (Neutron must be
restarted completely to start logging) and /NeutronMP/logs will
contain log files which would be interesting to check.
Best regards,
Neutron's log file did not seem to contain the correct log. (You also need to create a logs folder)
Therefore, this is the debug log of Android Studio.
Also, neutron's 32 bit output setting had to be invalidated.
- FLAC 24bit/192kHz : working (24_192_flac.txt)
- FLAC 24bit/352.8kHz: not working (24_352.8_flac.txt, error log: 352800 Hz is not a supported sample rate)
- WAV 24bit/192kHz : working (24_192_wav.txt)
- WAV float32bit/192kHz : working (float32_192_wav.txt)
- WAV int32bit/192kHz : working (int32_192_wav.txt)
- DSD64 : DoP playback with noise (dsd64.txt)
- DSD128: DoP not working (dsd128.txt, error log: 352800 Hz is not a supported sample rate)
The following is the log of FiiO Music.
FLAC 24bit/352.8kHz can be played. It seems that processing is done as 176.4kHz * 2 from the log.
Audioformat = 10 is not used to play the DSD file.
Audioformat = 7 (ENCODING _ DTS) is set in DSD64.
Audioformat = 8 (ENCODING_DTS_HD) is set in the DSD128.
AudioFormat | Android Developers
https://developer.android.com/reference/android/media/AudioFormat.html
I have not got any information from FiiO about sample rate above 192kHz file and DSD file.
If you want to play these audio formats, I think that you need to confirm details with FiiO.
- FLAC 24bit/352.8kHz: working (24_352.8_flac_fiio_music.txt)
- DSD64 : working (dsd64_fiio_music.txt, audioformat=7 -> ENCODING _DTS)
- DSD128: working (dsd128_fiio_music.txt, audioformat=8 -> ENCODING_DTS_HD)
Edit: insert log file link
  • 24_192_flac.txt
  • 24_192_wav.txt
  • 24_352.8_flac_fiio_music.txt
  • 24_352.8_flac.txt
  • dsd64_fiio_music.txt
  • dsd64.txt
  • dsd128_fiio_music.txt
  • dsd128.txt
  • float32_192_wav.txt
  • int32_192_wav.txt
Aug 8, 2017 at 3:07 PM Post #10,752 of 15,899
Sorry. I translated this post. ha ha
I attached log files with a post. However, these links of uploaded files are not displayed in that post.
How can anyone see it?
Update:
This problem was solved.
I don't know how to automatically insert the link of the uploaded file, so I inserted the link manually.
  • 24_192_flac.txt
  • 24_192_wav.txt
  • 24_352.8_flac.txt
  • dsd64.txt
  • dsd128.txt
  • int32_192_wav.txt
Aug 8, 2017 at 5:39 PM Post #10,754 of 15,899
Can you translate to English, please?
ログファイルを添付しました。しかしアップロードしたファイルのリンクが表示されません。
どうやれば誰でも見れるようになりますか?
you gota love google translate
he (?) says:
I attached the log file. However, the link of the uploaded file is not displayed. How can anyone see it?
Aug 9, 2017 at 2:22 AM Post #10,755 of 15,899
Changing tracks 24/192 while on coax out force closes the FiiO music application. DSD with bitrate of 5000+ is inaudible. My dreams of a transport with 2 mSD cards is slowly crumbling.
