gazzington
ThanksAre you using coaxial or USB?
If using coaxial, do you have a TRRS cable with the appropriate wiring (ie., signal on the Sleeve and the ground on Ring2)? Do you have the combined line-out / coaxial setting set to coaxial? Are you plugging the TRRS (four pole) end in to the X5 III and the TRS (three pole) end to the Mojo's coaxial input?
I know they're simple questions but that's all there is to it.
I shall check all of this when I get home from work. Its been frustrating as I have had the chord mojo working magicly with my sony phone (although I need to find a way of attaching the mojo to the phone to make carrying it around easier!)
