Next firmware request...
1. In folder view, is it possible to sort albums by "modified" date or created date?
2. Also in folder view, it would be nice if that once you choose a folder-then select a file, and then back back out into the main folder list... that the main folder structure remembers the last album you accessed, instead of going all the way back to the top of the folder list.
3. I now understand the always disappearing 2nd as card , as function of the processor limitation but is there a way to speed up the ability for the card scan/re-appear? It's slows down the device quite a bit imo.
4. Can we please have the option to change the stock launcher, or at bare minimum tweak the stock launcher app to a) allow icon packs, and b) add multiple home screens, such that I can have one screen with the fiio music app widget, a screen with a tidal widget, a screen with my podcast widget etc.
5.Also give the option to decrease the font size in the fiio app, for long folder names OR allow scrolling folder/album titles instead of the truncated label method used now.
6) and PLEASE speed up the blue power button, half the time I have to push it twice just to get the screen on, it's annoying.
I agree with many of these and would also ask if we could manually drag titles up and down a playlist, so we can define the order.
But I wanted to tell you @newtophones07 that you can already have multiple home screens. If you have more than one icon on a screen, you can drag it to the right and create new screens. If you are placing widgets you can do the same, or you can place it to the right immediately, from just after you've long pressed it from the widget list. Hope that makes sense.
#2 would make a big difference - when you go up one level from a folder, that 'last accessed' folder should be in the middle of the screen. Currently we start at the top of the list of folders again.
Also, it might help to put @FiiO at the top of a feature-request post, to make sure they are alerted
