x RELIC x
@ClieOS
- I know you mentioned already you didnt notice a .5 second mute of tracks when using the mojo with the x5iii but could you try playing a track then select a different track with a different sample rate (eg 44k>96k) when you get chance? Its the change of sample rate that causes the small but noticeable mute at the start of the track.
Will the coax cable required for the x5iii be the 4 pole as per the x5ii?
Does the x5iii do bitperfect?
@JamesFiiO
- will the x5iii support larger microSD cards when they become available?
Thanks!
The 0.5 second mute when changing sampling rates is a part of the design implementation of the Mojo and you'll encounter it when there is a sampling rate change with any device.
Please read this post from the Mojo thread:
http://www.head-fi.org/t/784602/chord-mojo-dac-amp-faq-in-3rd-post/28110#post_13134129
You will need the 4 pole TRRS coaxial adaptor, or a custom cable for the TRRS configuration, to output coaxial from the X5-3 as it shares the same line-out/coaxial configuration as the X5-2, confirmed earlier in this thread.
