WayTooCrazy
Nice, I tried to solder one of those TRRS plugs and they are way too small for my poor solder skill set. How about a photo of the plug with cap unscrewed to satisfy my curiosity.
Maybe the next one. I typically cover the solder connections with Shrink tubing. It would be nearly impossible to remove the tubing and get another on without un-soldering the connector all over again.
Hint: 1. Get a decent iron and a pointed tip. 2. use an X-Acto knife to scratch the soldering points on the plug and then tin them. 3. Lastly, you can do the shield and tip straight on, but the Ring 1 and Ring2 would be easiest if you do them at 45 degree angles (either side) or more (greater angle if possible).
