javre76
- Mar 15, 2016
Yup.
Still stand by every word.
The X5iii is fantastic. Has a musical sound with lots of detail. DX200 is a very analytical stone cold neutral playback that sounds nothing like a home system a car system a live show or anything. Put another way, sounds nothing like listening to music in life unless you are a Studio mixer using studio cans putting layers onto a master track and need a dead neutral zero point to accurately mix the master.
If the EQ were as effective as one would imagine going from flat it would be a non issue for a tweaker like me but it is not easy to manipulate with a 10 band graphic. A parametric? Maybe. Graphic? no way.
Are there any good third party leather cases? I searched for one when I bought the dap but not much success in finding one. I'm using the clear plastic case it came with until I find a better option.
Apparently Dignis and Tuf Luv are working on their versions for the X5III. I want a nicer one, too.
Hey,my dap is x5 1st gen and I am planning to upgrade.Do I need to buy x5 3rd gen or buy a v20(v20 is only $50 dollar more than new gen x5 here in india) because my current phone is a mediocre one.if the sound quality is almost equal then do u think v20 is a better investment.since you own both of them what is your suggestion broto.(my iems titan1,macaw gt100s and hd598se cans).any others using both?
Hi all. I've managed to run TWRP 2.7.0.0 on Fiio X5-iii:
There is still something to polish, but almost everything works.
I'll post the files when it's finally ready. Stay tuned.
and even if Ibasso dx200 is better I don't think it would be worth 600$ more. Is it? r
Which TRACKS did you listen to ?It worth. I owned X5iii and sold it to get DX200.
X5iii surpasss many DAPs in his price rate up to 1000$ but DX200 surpass many DAPs that cost more than itself too.
I still in love with X5iii sound which smooth and sweet which I can't find it in my DX200 but DX200 give me a delicate, reference sound which X5iii can't give me.
I don't say that X5iii is bad.
My intention is both DAP are giant killer DAP in their price range.
But it just my comment plus my taste of listening and pairing. With different ears, taste, headphones, I may judge in opposite way.
Not that equal, X5iii still get over this phone in many categories eventhough not a hugh step.
But from other dactor, I recommend you to get new phone which you'll get many profits for your life then you can aim for higher DAP later. In my opinion, V20 can compare to DAPs in range of x3ii which is great for smartphone.
I have mostly FLAC, ALAC on my X3iii. I do have a few others like AAC with embedded art that show up just fine.
Hi!
Does X5-III support .Wav files? Seems like standard fiio player does not..... But i can do it by Poweramp.
And it does not support 32/192 wav files at all....
Would you improve it? @FiiO
Hi!
I found .WV format not supported .
Yes i use Foobar2000 to play .WV
