superuser1
Red does look nice but I think I'll stick with black and maybe get red case when it's out haha
My sentiments exactly. Have a titanium and will get the red case. @FiiO has noted down my special request.
Hi mihaig,
you can insert the Micro SD card into slot 2, to see the seed will be better or not ?
I did. Average speed is almost triple now. Took some screenshots using slot 1 and slot 2.
@FiiO, can the sandisk wireless stick work with x5iii?
Hi (to maybe somebody from Fiio)!
I just received my X5 III - and coming from an Onkyo DP-X1, I really like the more musical sound, the smaller form factor and better battery life!
But I am having the following issues:
1. The Android EQ of streaming apps (Spotify and Apple Music) does not seem to work with the X5? It is shown properly in the menu (see picture), but if you use the sliders there are no sound changes at all! It worked flawlessly (and surprinsingly well) on my DP-X1! Interestingly enough, after plugging in a balanced cable, the two extra sliders for "bass" and "surround" get greyed out (second picture). I remember that actually the latter also happened on my DP-X1 at the beginning, but disappeared after a while (maybe due to a software update)? So I suppose this is either a software bug or the Android EQ is switched off in the Fiio firmware?
Any solutions anybody? I find it kind of a pity not being able to use the Android EQ, because Viber Effects also only work in the Fiio Music App and not system wide....
2. It seems that is does not work to set up a " launcher" as a standard screen, to create one`s own skin - as it is usually possible on any Android device (and was on my DP-X1). With the Fiio, it says "Select dodol Launcher, then tap ALWAYS", for example, but actually nothing happens. Is this also not allowed by the firmware?
3. The download speed for streaming Apps is really, really slow, it takes maybe four to five times (!) longer than it used to take with my DP-X1! Is this buggy, too, or does it have any other technical back ground?
4. The stand by light is always blue - is it still ok to leave the device in stand by mode without losing too much battery? I actually never swiched my DP-X1 off and it did not use much battery in stand by (at least if I had Wifi off). Also, I realized that pushing the stand by button on the X5 after the screen turned black, it sometimes starts or stops playing music - must be a bug, too, I guess?
Thanks for any solution!
it's only one day left to this week
end game ? I heard this from you a few times.i got my fiio x5iii dap today, simply love it and i added to it the fiio a5 amp wow
really love this combo, this is an end game setup
more impressions to come comapring it to cowon plenue m2
end game until a new totl dap is released that ticks all the sweet spots i need in a dap
i really like what i am hearing alot
i am a big fan of this dac which is found in ak380
i put a hold on buying the new cowon dap as its a bit expensive and i have the cowon m2 so i will wait a bit until i get more impression about the new cowon p2
but man this fiio x5iii is really great dap
X5III can do a lot very well.end game until a new totl dap is released that ticks all the sweet spots i need in a dap
but man this fiio x5iii is really great dap add to it the a5 amp what else is there to desire.
Great, please post the comparison to the plenue M2 which I have been eagerly waiting for.
and compare to the DX200.will do soon
