FiiO M9 , Android based Hi-Res smart DAP with 3.5/2.5 powerful output|AKM4490 X2 |WiFi|aptX/aptX HD/LDAC/HWA(LHDC)|USB DAC|USB AUDIO OUT
Discussion in 'Portable Source Gear' started by JamesFiiO, Aug 10, 2018.
6 7 8 9 10 11 12 13 14 15
17 18 19 20 21 22 23 24 25 26
  1. MPNow
    @JamesFiiO @FiiO USA @FiiO I was wondering if this device will support bandcamp as well.
    Also, is there an official US price yet for this product? I read around $230-300 ish...
  2. Brooko Contributor
    Yes to both - and sorry ..... a lot of travel, currently overseas now. Will have GT3 SB and also BTR3 posted this week. X7ii on my radar after that (well overdue)
    trellus, ValSilva, dsrk and 1 other person like this.
  3. purk Contributor
    Guys,
    Can the M9 output DSD signal or the signal is down converted to 24 bit PCM? I'm looking for a DAP that digital DSD signal at 24-88.2 or 24-176.4. Thanks.
  4. FiiO
    Dear friend,
    The M9 runs on deeply customized system. There are four 3rd-party apps preinstalled on the M9, and they are Tidal, MOOV, KKBOX and 网易云音乐(NetEaseCloud).
    To ensure system stability, only certain apps in our white list are allowed to be installed. You can copy the apk file of the qualified app to the M9, then open the File Management app, locate and click on the apk file to install it.
    The apps in the M9's white list are inlcuding Spotify, Qobuz, Roon and Deezer, and the app download links for them are as follows:
    Spotify: click here
    Qobuz: click here
    Roon: click here
    Deezer: click here
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
    trellus and seanwee like this.
  5. FiiO
    Dear friend,
    No, for M9 the DSD file would not be down converted.
    Best regards
  6. Focux
    sorry but i can download TIDAL and use it on M9 right?
    just curious cos i enjoy the Masters quality on TIDAL which is only available on the desktop app i think
  7. FiiO
    6. FiiO M9 Hi-Res Audio Player丨The Ultimate in Versatility
    The M9 can be used as an asynchronous USB DAC with both Macs and Windows PCs. It can also act as a Bluetooth transmitter – hook the M9 to your computer as a USB DAC and then transmit Bluetooth audio to your headset!
    trellus likes this.
  8. mandello
    Please help me, I've just few hours to decide between M9 and X5 III, the best goal is audio quality, the second is Bluetooth and tidal, which one to choose???!?!
    Thanks for helps....
  9. seanwee
    For sound quality go for the M9. However, I'm not sure if the M9 supports Tidal.
  10. purk Contributor
    Thanks.
  11. stenog
    According to all information at this stage the M9 should support Tidal, streaming and offline. But of course we need someone to actually use it. :)
    As long as the M9 uses the original Tidal app I can't see there should be any problems. Be it apk files or preinstalled. The same should be the case with Spotify or any other player.
  12. thrgk
    where can US customers get one? Penon audio doesnt have any
  13. stephanemtl
    I intend to use the M9 as a USB DAC, connected to my laptop. I also want the M9 to send the resulting analog signal to a dedicated headphone amplifier. Is the M9's line out a 'true' line out that bypasses the M9's internal amping section? I want to avoid double amping.
    Can the USB DAC function be used simultaneously with the LINE OUT function?
    Thanks
  14. Focux
    Only problem is that the best audio quality TIDAL offers is not available on the app
  15. Sound Trooper
    can this do offline tidal?
