mikp
- Jul 17, 2011
im just getting error while initializing equalizerIf you swipe to the left whilst on the EQ page it changes to dials and there is a toggle to switch the EQ on and off.
I went ahead and bought the version from Poweramp. It's been like 5 years with the old license anyway. S
uper simple to activate on the M6 after that. Poweramp has really come a long way over the years.
hey all. I saw Last.fm is now a whitelisted app on the m6. However, has anybody got it to work? I can start the app and login, but I think the app may get closed whenever you go back to the home screen and start music. It doesn't seem to scrobble properly, and when I am playing music, either with Fiio Music (old and new versions both) or Pulsar, and I then open the Last.fm app, then the music stops completely. Seems to be crashing a bunch.
Honestly, I'd prefer to use something like the Simple Last.fm Scrobbler, but since that app isn't whitelisted, I can't get it to work. I've been trying to impersonate a whitelisted app, as has been done by others in this thread, but no luck so far. However, that might be because I don't really know what I am doing so far. Anyway, anyone got Last.fm working? I love the m6, but I really really miss having my songs scrobbled to last.fm.
Actually, an update. I modified the APK for Scrobb for Android, which doesn't crash for me, and so far works perfectly fine with both Neutron and Pulsar. Fiio Music refuses to cooperate with Scrobb though, so I can't use that anymore. Ah well. Now I just need to find a way to use Neutron on the M6, or more specifically, I need to figure out how I can buy and activate Neutron on the M6. Has anyone managed this?
Which version of Neutron did you try. The one that could be activated played nothing but static for me. The ones that actually work don't have a place to register.Yeah not wanting to deal with the hassle is pretty understandable. However, I've really been having a nice time with my M6. It's nice not to have to carry a phone around at all times, and by adding a 128 gb microSD I have a pretty great setup. Tons of music, good audio and portability. The faffing around with apps was annoying, but I have everything working now. Bought Neutron and got it activated properly, and by modifying the Scrobb apk I can now keep my last.fm up to date as well. It's honestly pretty great. If there is interest I can post the Scrobb apk somewhere as well; I can imagine there are more people that could use Last.fm integration with their Fiio.
Edit: concerning Neutron: I have been looking at this thread, http://neutronmp.com/forum/viewtopic.php?f=3&t=4014&hilit=fiio which lists a number of options to enable for Hi-Res audio. Am I wrong in thinking that the M6 should support this? In particular, this section seems to suggest that Hi-Res audio is currently not enabled on my M6, or I may have some settings wrong.
If you wish to to know whether your device has Hi-Res Audio support just access Audio Hardware -> Frequency section. Hi-Res Audio capable devices will have multiple frequencies listed, Bits field will show 24 or 8.24 or 32 in [out: X] placeholder. Additionally you can tap on a panel with Channels, Bits in Audio Hardware and see the current audio output format. If all audio devices indicate 'closed' during playback then it is a sign of Hi-Res Audio as well.
Wow you're lucky ... i almost tore my hair off trying to get that version to workThe one I'm using is Neutron Music Player v2.11.0 (Paid) (ARMv7+NEON)
https://a2zapk.com/552692-neutron-music-player-2-11-0-paid-armv7-neon.html
I already had the paid full version of Neutron - running on X7ii. I just downloaded and installed this version - and it worked OOTB.
Perhaps its the file format? Who knows...Wonder why it works for me? Latest firmware. Installed. Worked. Files are aac256.
