Thanks, but that's not really what I was looking for. I want a case to put the M6 into, like this one, but that also covers the screen. Like the type of cases you see for smartphones
[FiiO M6] Portable High-Resolution Lossless Music Player,Embracing A Wireless Future
Dietmar Görtz
Hi,
I have a Chord Hugo 2. Can I connect the M6 to the Chord Hugo 2.
Can I bypass the internal M6 DAC?
The Hugo 2 has Micro USB, the M6 has USB-C. Is there a cable for it?
Many thanks,
Dietmar
Many thanks,
Dietmar
I use M6 in Italian.
In the Settings -> General -> Sleep Timer menu the items: Sleep and Idle poweroff are inverted.
That is, if you set IDLE POWEROFF, M6 turns off after the set time regardless of whether you are using it or not (so it is basically a sleep) and when you turn it on again the timer is reset
If you set the SLEEP, it will not turn off if M6 is making music, at the indicated time, but if you pause or stop FiiO Music then turn off (so it's an IDLE POEWEOFF) and especially when you turn it on again, the timer turns out to be set .
Report to @FiiO the problem.
djricekcn
- Dec 2, 2014
can anyone link this in English? When I tried searching this product in English mode, it doesn't pick up at all
How about this one--a store of our cooperative partner: https://www.aliexpress.com/store/pr...-Leather-cover-Black/4673052_32961552386.html
djricekcn
- Dec 2, 2014
The web page is in German (?). Again when u change it to English it won't pick upHow about this one--a store of our cooperative partner: https://www.aliexpress.com/store/pr...-Leather-cover-Black/4673052_32961552386.html
eclein
Old guy here, how do I “side load” Spotify?
I’m guessing that I download apk file or whatever it’s named onto M6’s open 2 gb partition. Navigate to it with file explorer app I see, tap it, it installs and I’m good to go....correct or no?
Thanks!
Thanks!
hsilmi
Thanks!
it doesnt have to be in to internal memory i guess. i saw on youtube people can also put the .apk in micro SD card.
Unknown757890
Sorry for my ignorance, but what do you mean by bluetooth amp? As in : headphone amp and bluetooth receiver? But the specs only show it can receive SBC and LDAC over bluetooth, which makes it not really useful for iPhone users.
You can connect it to a device and then it will act as a Bluetooth amplifier. And yes it actuality is useful for iPhone users + Airplay.
Unknown757890
1. High-Res Audiowhy dont you buy iTouch instead. its suits your need better. this device made specially for listening music i guess.
2. I have the Sony wh1000xm3’s
3. LDAC
4. SBC
5. Qualcomm aptX HD
6. + USB C
7. USB DAC
8. Airplay
9. Supports Micro SD
10. online upgrade
11. 2018
12. It’s not by Apple. [sorry Apple fans]
This thing was made for music. Don’t guess that, everyone knows that.
They are in China, you may change a explorer for a try and make sure there is no de. before the link. Then you will see the English page.
Thanks!
Yes, if the app is in the whitelist.
hsilmi
1. High-Res Audio
3. LDAC
4. SBC
5. Qualcomm aptX HD
6. + USB C
7. USB DAC
8. Airplay
10. online upgrade
11. 2018
This thing was made for music. Don’t guess that, everyone knows that. To have it be able to play videos would be kinda nice. That’s all what I am saying.
dude c'mmon, this Fiio is a DAP (digital audio player), shouldnt be that obvious to you?
anyway my suggestion for apple came from sarcasm -.-"
if you want serious oppinion, i would suggest COWON products. most their product support video player and have good sound quality plus they have longer lasting battery.
geez people now a day are really made from thin papper, really takes everything seriously
Unknown757890
Anyway I have this DAP and I am pretty satisfied. And COWON products are fat & bulky and the price are too. That’s were the batteries are I guess.
