[FiiO M6] Portable High-Resolution Lossless Music Player,Embracing A Wireless Future
Jul 25, 2019 at 11:20 AM Post #2,626 of 3,610
Interesting that we can now use the Newpipe app. Newpipe can force youtube video into landscape mode. Am watching a video in landscape right now but somehow the brightness cannot be increased. Good anyway because you can listen to all the youtube stuff.
Yeah! NewPipe was one of the apps I really wanted to be whitelisted, it's a great idea in fact, as it won't rely on your google id, it stores your choices locally in a favourites file. Great idea and it's quite snappy!
Jul 25, 2019 at 12:06 PM Post #2,627 of 3,610
Yeah Neutron and Poweramp trials don't seem to work at their latest version. Gotta dig for older ones. If a licence can be recovered that's valid, else.. well I don't like trials in general :)
Something very strange, VLC is installing but it swaps its icon with SambaPlayer. Lol something's going on. Maybe some reset is in order. Anyway both work fine !
Jul 25, 2019 at 1:05 PM Post #2,628 of 3,610
Hey @FiiO can you check if you inverted the SambaPlayer and VLC player icons? That seems to be the case :wink:
Jul 25, 2019 at 1:54 PM Post #2,630 of 3,610
An interesting addition is doubleTwist Pro.. But I don't seem to be able to get any apk to work.. it launches the installer and it quits immediately.
Have any of you had luck with this app and which apk did you use? Thanks!
Jul 25, 2019 at 2:35 PM Post #2,631 of 3,610
Some of you seem to know which apps are white listed.
Is there a list or something?
Jul 25, 2019 at 2:45 PM Post #2,632 of 3,610
I can't seem to get Neutron to work. Just hiss all the time. I installed the arm7 version but no luck. Any recommendations please...
Jul 25, 2019 at 3:00 PM Post #2,633 of 3,610
Jul 25, 2019 at 3:10 PM Post #2,634 of 3,610
Jul 25, 2019 at 3:22 PM Post #2,635 of 3,610
Jul 25, 2019 at 3:31 PM Post #2,637 of 3,610
So if I wanted a small compact player that supported audiobooks (and I see that smartaudiobook is on the whitelist now which is great) would the m6 still be worth a look? Got a hiby r6 which is fine but a bit big. After something reasonably small so I can shove in the pocket and forget about it at work. Got the shanling m0, nice player but no audiobook support despite a)being requested and b)promised, Sony A35, again no podcast/audiobook support which is annoying as it would be perfect otherwise. Would be using custom art fibae 2's and blacks with it.
Jul 25, 2019 at 3:35 PM Post #2,638 of 3,610
what is the common scantime for the library? Tried the sandisk 400gb that is 90% full, or 14.000 tracks, and with fiio or poweramp it takes ages as in hours. But with jetaudio it took 13min to rebuild library.
Im waiting for a samsung evo plus 512, dont know if that will make any difference.
Jul 25, 2019 at 3:41 PM Post #2,639 of 3,610
Jul 25, 2019 at 3:42 PM Post #2,640 of 3,610
Did you try Simple ABP Free or something like that? I think it's for that.
