hi
@FiiO when are you releasing a new firmware for the M6? Last I read through, a post confirmed that it will be released sometime in April?
I can confidently assume that the audio skipping is caused by the instability of the music app. the audio skip or "glitch" happens when the player tries to play the song immediately as soon as you move to the next track. it seems like the player tries to be gapless in its playback, but stutters as a result
When I restart the app by exiting the app and then opening it up again, the music app plays the songs without hurrying (there is a very normal brief gap that is uninterrupted by audio, as it should be). I assume that after prolonged use, the glitch will appear again, and the player will try to hurry to play the next track that you are skipping to, resulting in the audio stuttering.
(The app restart doesn't seem to fix the issue every single time, so it's unreliable as a fix for the time being)
While editing this post, i have gone through the restart cycle a few times after every encounter with the audio glitch. Even the restart does not solve it immediately.
Also, turning off gapless playback does not solve this issue. the issue appears after skipping through a few songs
@FiiO , please, can you look up this issue? I am no software engineer, but it does seem like some sort of instability within the music app. Alternatively, it also has to do with the app cycling through various music file format, and changing from one format to the other in quick succession causes the glitch.
