magnificientako
- May 1, 2006
Yes x3 1st gen has micro usb port. I am using lightning to usb camera adapter cable.
Dear friend,Can anyone confirm if the Fiio M6 also supports micro sd cards with 1 TB storage?
Maximum storage expansion | Theoretically 2TB (only one micro SD card slot) |
Well, I’ve been waiting for this as well but it seems FiiO has not supported nor updated the M6 for some years now. To use Apple Music I connect my iPhone via AirPlay to the M6 and play Apple Music through this connection.Can this player still do streaming in 2023 ? Just wondering if I would be able to use Apple music on it , if not already Spotify lite or something .
Thanks
Well that's the whole point of having a dap so I can disconnect from phone.Well, I’ve been waiting for this as well but it seems FiiO has not supported nor updated the M6 for some years now. To use Apple Music I connect my iPhone via AirPlay to the M6 and play Apple Music through this connection.
I don't use paid streaming, I use internet radio a lot. As an application on my M6 I use VRADIO which also allows me to listen to radios with HI RES type SuperStereo (HiRes 24-bit/192kHz, HiRes 24-bit/96kHz and 16-bit/44.1kHz) or simply radios at 128K/ 256KCan this player still do streaming in 2023 ? Just wondering if I would be able to use Apple music on it , if not already Spotify lite or something .
Thanks
Spotify from apkpure works.Can this player still do streaming in 2023 ? Just wondering if I would be able to use Apple music on it , if not already Spotify lite or something .
Thanks
Is the experience smooth enough ?Spotify from apkpure works.
The interface can be a little unstable, but the music is good. Turning off Canvas - the videos that want to play when the screen is on and music is playing helps smooth the interface..Is the experience smooth enough ?
in 2023 i would personally look for something else. I still have my old one if you want to buyIs the experience smooth enough ?
Well I would prefer something else but I find android players distracting and sold my a-105.in 2023 i would personally look for something else. I still have my old one if you want to buy
