FiiO M6-Portable High-Resolution Lossless Music Player,Embracing A Wireless Future
Apr 5, 2021 at 7:02 AM Post #3,436 of 3,471
DietmaR
Germany
sorry, forgot to update. I too had problems with 2.26.1. So I uninstalled, then installed 2.25.0 with the APKPure app. Re-downloading playlists took ages!
I wish the M& had a better processor & more RAM. Love the form factor, but MQA on Tidal just seems to much for it. Using with ifi Hip DAC & Chord Mojo. Sounds great, but stutters a lot.
Would buy the M11, but it's a bit too big for my liking. Lets hope the M6 mkII isn't too far off!
Hello,
How did you manage to run if Hip DAC with the M6? I connected the ifi Hip DAC via a OTG cable (USB-A female to USB-C) and nothing happened. I tried some developer settings, e.g. USB debugging but no difference.
Thank you!
Apr 25, 2021 at 10:39 PM Post #3,439 of 3,471
FiiO
Sponsor: FiiO
Guangzhou,China
Hi everyone!!
Does anyone able to get the LCD and Touch from any other vendor than FiiO?
@FiiO Could you sell the mentioned spare part?
Greetings In advance.
Dear friend,
Yes, I will PM you the link for purchasing the display to you.
Best regards
May 30, 2021 at 11:34 PM Post #3,443 of 3,471
FiiO
Sponsor: FiiO
Guangzhou,China
Olá, posso decodificar o MQA de TIDAL em UAPP em FIOO M6? Estou usando o UAPP no FIIO M6, com a ajuda do HIBY FC3, no entanto, não há luz verde ou luz azul do MQA STUDIO.
The M6 does not support MQA. If you are playing MQA file via Tidal app in the M6, you could only get MQA 2X unfolding.
Best regards
Jun 3, 2021 at 1:46 AM Post #3,444 of 3,471
BenjaminJohnson
I don't know if there is better place for this info, but YouTube Vanced works great with the M6 and Via Browser works great too! YouTube is not the greatest for sound quality but it still sounds better on the M6 then it does on most phones.
Jun 17, 2021 at 10:27 PM Post #3,447 of 3,471
Knightsfan11
How does the m6 compare with newer models of FiiO players, as well as the Sony walkmans such as the A55 line of units?
Jun 18, 2021 at 3:34 AM Post #3,448 of 3,471
FiiO
Sponsor: FiiO
Guangzhou,China
Dear friend,
You could read some more information about M6 in our website first: https://www.fiio.com/m6
And if possible, you could try and compare by yourself.
Best regards
Jul 18, 2021 at 2:53 AM Post #3,450 of 3,471
TQuartic
North America
Hi everyone, i need a little help with my M6. I ordered it from Aliexpress in 2018 and its been excellent. About 3 months ago i unplugged it from my iPhone charger (always used this) on my way to work and it froze. I was running late so i just hard reset it (Power + Play for 10 sec). After the reset the backlight came on but the display did not show any image. I pressed play and music resumed, touch screen functionalities still work and other functions continue to work well (bluetooth, vol, etc). Its been like that for about 3 months now. Does anyone know how to fix this?
