czajunia
- Aug 3, 2013
I don't suppose there is a clip case available for M6, is there?
Many thanks.
Many thanks.
Nothing that I'm aware of. Closest thing would be the DDhifi case which has a metal link to attach to a keychain: https://hifigo.com/products/fiio-c-...usic-player-black?_pos=1&_sid=d54b73f90&_ss=rI don't suppose there is a clip case available for M6, is there?
Many thanks.
Thanks a lot for the link. I guess it's a very nice case to carry the player around adding extra protection, not so good for sports unfortunately.Nothing that I'm aware of. Closest thing would be the DDhifi case which has a metal link to attach to a keychain: https://hifigo.com/products/fiio-c-...usic-player-black?_pos=1&_sid=d54b73f90&_ss=r
Is it just me or the stock music player really sounds dull and boring like a smartphone sound? I just installed poweramp with hi res output, and it sounds way better with better detail and separation, and more fun tonal.
Looking for some help. Have purchase a M6 and the fiio music app keeps coming up as not responding and asks to close or wait. So I updated the firmware and now the whole unit just crashes and freezes.
Took it back to the shop and they switched with another and same thing. Have used different cards as well with same results. Pretty well stuck as from factory the music app crashes and upgraded whole unit crashes. Any advise or help greatly appreciated.
Thanks Ed
Did you try taking out the sd card and doing a factory reset?Unfortunately to get the other apps you need to upgrade the firmware which then causes the whole unit to crash and freeze. The problem seems to be the base operating software
Hi,Looking for some help. Have purchase a M6 and the fiio music app keeps coming up as not responding and asks to close or wait. So I updated the firmware and now the whole unit just crashes and freezes.
Thanks Ed
Will try this when I get home. ThanksHi,
Please try to clear the data of the FiiO Music app from system settings-General-Apps-FiiO Music app-store -clear data. Then restart the FiiO Music APP to check again first?
Best regards
