mikp
- Jul 17, 2011
check running services in developer options.How does one check for and disable autostart on installed apps? There are no options available when viewing an app via Apps > Settings. Only memory and battery used recently is shown.
you can use "app cloner" to disable auto start on a apk, then install the cloned one. I think deezer used 30mb at start.
