djricekcn
- Dec 2, 2014
Thanks for the info Marco.
Btw, do you happen to know in what format it's best to put the micro-sd card in? For the Fiio X1, they recommended to put it in exFAT. Should I still use this, or go for the more common used FAT32?
And do you perhaps know if there is a way to see what the latest added albums on the micro-sd card are? I guess, since it's Android-based, that this is possible. So I mean when you put files on your card, that you afterwards can see on the player the latest added albums, going from most recent added albums to less recent added albums...
Thanks in advance!
For me, I'm getting the opposite. It's not in my pocket, rather, it's literally directly with the headphones but i get stutter and so on pretty commonly. I don't know if it's because I'm trying to do LDAC (Quality priority) (there's three different LDAC settings - Connection Priority, Normal, Quality Priority) but i'm getting roughly one stutter a song, if not more.
