[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
Thank you for the quick response and clear explanation. I love your open and honest way of interacting with your customers here on Head-fi; looking forward to my M17!The SRC has been bypassed in Android underlying processing for the APPs in FiiO M17. However, you would need to check whether the APP itself has SRC. If yes, the output sampling rate may not be consistent with the sampling rate of the music file.
Best regards
Regards
Photo A to my mind is cleaner and more refined, though I'm not a fan of this RGB thing and am totally baffled by the appeal, to be honest. When I think RGB lighting, I think gaming keyboards. Probably/maybe it's a generational thing....Thank you so much for your opinion on the ID design of the Q9. We will finalize the front and back designs of the Q9 based on opinions of users at home and abroad (From the current result, Chinese users prefer the one with heat dissipation marks just like the M17 while overseas users hold an opposite opinion).
We are still optimizing the RGB light design. Here are two different schemes. The first is an integrated design with all ambient lights in one. These lights take up larger space for an obvious light effect. The second is to add more lights based on the M17. Which one do you prefer?
You could vote at: https://www.head-fi.org/threads/vot...9-part-ii-evolution-of-ambient-lights.960906/
Picture A:
Picture B:
audionewbi
- Jan 24, 2010
Is there a possibility to add a microSD card to this, so we can use this as a chord mojo?Thank you so much for your opinion on the ID design of the Q9. We will finalize the front and back designs of the Q9 based on opinions of users at home and abroad (From the current result, Chinese users prefer the one with heat dissipation marks just like the M17 while overseas users hold an opposite opinion).
Picture A:
Picture B:
"The M17 makes use of the 8-channel D/A converter following the method A."! Good to know that it is 8 channels with 4-4 in parallel per chip are being used ! I found your explanation on data sheets
A. Connect the 8 D/A converters in parallel and then pass the parallel signals to a public I/V converter before output.
The1Signature
how do i check this?However, you would need to check whether the APP itself has SRC.
i guess 99% of us will have the same 3 apps on it:
- qobuz
- tidal
- uapp
Well, for one, the Tidal android app is bit-perfect. See this article on it.how do i check this?
how to we know that qobuz bypass the src? because you modified the android OS in that way? and regardless of future updates of tidal or qobuz, both apps with ALWAYS bypass src?
- qobuz
- tidal
- uapp
- Oct 14, 2013
Ah my bad, was half awoken LOL."The M17 makes use of the 8-channel D/A converter following the method A."
Ok, I think I found what caught my eyes back then
Parallels all 8 channels will result in 25Ohms output impedances. Many Opamp used in I/V stages in U1 and U3 will have difficulty maintaining low THD and Linearity. For ES9038Pro, it is recommended to parallel the DAC output after the output of U2 and use a set of Opamp for all 8 channels U1, U2, U3.
That explains why FiiO used 1 single channel OpAmps for I/V stages
This is true.The SRC has been bypassed in Android underlying processing for the APPs in FiiO M17. However, you would need to check whether the APP itself has SRC. If yes, the output sampling rate may not be consistent with the sampling rate of the music file.
Best regards
UAPP has it but, it has to be implemented to the particular DAC, for instance, DSD works with the Q5s but it gets converted with the M17.
By contrast, the Fiio app keeps the DSD file intact t
- Oct 14, 2013
I would go with A for sure , so I agreedPhoto A to my mind is cleaner and more refined, though I'm not a fan of this RGB thing and am totally baffled by the appeal, to be honest. When I think RGB lighting, I think gaming keyboards. Probably/maybe it's a generational thing....
littlexx26
what about lks004?Ah my bad, was half awoken LOL.
- Oct 14, 2013
They used discrete stages for all channels if I remembered correctly. It has been a while I haven’t visited the DAC. It appears that they run 4-4 in parallel with discrete components to compensate for the linearity and THD that OpAmps can’t tackle as the data sheets mentioned. This opened up a lot of rooms for those DIY to play around with it as wellwhat about lks004?
One last question for @FiiO , does M17 use True Line Out ? And not Pseudo LO ?
littlexx26
oh you not listen to it anymore?They used discrete stages for all channels if I remembered correctly. It has been a while I haven’t visited the DAC. It appears that they run 4-4 in parallel with discrete components to compensate for the linearity and THD that OpAmps can’t tackle as the data sheets mentioned. This opened up a lot of rooms for those DIY to play around with it as well
- Oct 14, 2013
I do, just don’t play around with it anymore, so all the hardware stuff on it escaped my mind LOL!!oh you not listen to it anymore?
The DIY community is going crazy over it for sure, and I know they have poured so much $$$ into improving it with great results. I have left it as is for a while now
Of course it is true line out
Total: 6 (members: 0, guests: 6)
