Yup... that's it... M17 on Mains connection, playing through Neutron Music Player at 8x OS fed from a Micron Industrial SD Card. Absolutely wonderful!
I know is good. I had in my beta 22Yes, I would recommend it if you can DIY. It has all the discrete components and excellent design
it seems iFi Audio iPowerX is 5V/3A and iPower Elite 5V/5A .. both don't have the 12V/3A required by the M17..And if you can't DIY?
Does something like iFi Audio iPowerX do it? Or do you need something like iPower Elite (pricey)?
There are several models 5V, 9V, 12V and 15V and iPower X spec are as follow :it seems iFi Audio iPowerX is 5V/3A and iPower Elite 5V/5A .. both don't have the 12V/3A required by the M17..
Nope - haven't experienced that during the last two weeks of having the M17. The apps I have been using include FiiO's, Musicolet, Tidal and UAPP. No crackling sounds so far...Is anyone else having the crackling noise?
It is the exact noise you get when you plug an audio jack into a a socked while the system is powered on. Except, of course, the jack is inserted.
it happens when the player is paused, or on standby for a while and then I start listening to music again. It also happens when changing modes or apps.
It isn’t random and it only happens when the unit has been on standby or paused for some time or, when changing from one app to another). It is brief not loud and it does not continue while the unit is playing music. Shennheiser HD820 4.4mm balanced over-ear headphone gain. I suspect is the amps and dacs powering down and up again to save battery and manage heat. but, I might be wrong and I actually have a faulty unit.Nope - haven't experienced that during the last two weeks of having the M17. The apps I have been using include FiiO's, Musicolet, Tidal and UAPP. No random crackling sounds so far...
Dear friend,I have now tried all my headphones and earphones. Balanced and unbalanced, on battery power and on DC power. The crackling is there regardless. It only happens on first opening the app or coming out of standby /pause. If I have 2 apps playing the same song (or a different one) and switch between them, everything is fine but, if for instance, I have Qobuzz going close it and then open the Fiio app (or UAPP) the crackling will be there briefly after first hitting play. it is subtle, very brief and nothing mayor, it doesn’t affect the rest of the listening session (continued without pause) or the sound quality (which is excellent) but, it is there and it’s annoying me.
I am not sure if this is the case. On my unit, only the Fiio app acknowledges DSD tracks (the lights go green) Neutron and UAPP acknowledge Hi-Res tracks (lights go yellow) But they stay yellow when playing DSD. I am curious to hear what Fiio has to say too.I am wondering whether the M17 uses the same DAPS (Digital Audio Purification System) as for example the M11 plus. meaning the audio of any app is sent bit-perfect to the DAC's (without android SRC stuff)?
And am I correct in assuming that the FPGA of the M11 plus has been replaced by the XMOS chip in M17?
I am curious because I am contemplating on getting an M17. Perhaps @FiiO or @JamesFiiO know the answer?
Regards!
I sent an email to the German distributor one week ago and today I found that their response was in spam. So, yes. they have it in stock since last week.They don't think other countries in Europe received the M17 at this stage too.
