[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
May 29, 2022 at 11:31 PM Post #3,991 of 5,690
@FiiO What about adding LHDC to the M17 or, LDAC, aptX-HD to the UTWS5, would that be possible?
Dear viffer,
1. LHDC to the M17: We have recorded and reported to the engineer for assessing.
2. Currently, the UTWS5 does not support LDAC. But as the application party, we are working hard with our partners for stable and efficient audio transmission.
Best regards
May 29, 2022 at 11:39 PM Post #3,992 of 5,690
@m8o Yep, I go from this:
To this:
And back to the first pic if I press again.
Dear friend,
You would need to switch the theme-now playing page to default first. Then tap the album art in the now playing page and you will read the VU meter.(DSD file not supports)
Best regards
May 30, 2022 at 1:29 AM Post #3,993 of 5,690
What was great was the implementation of a real vu meter like the McIntosh amplifiers that says what is the power output in real time, come on Fiio make this real
Yes. Agreed. The meters on my McIntosh MHA-100 are nothing less than mesmerising -- stunningly fast and accurate -- that are hard to look away from. Damn I love that amp! :D
edit: point being, contrast that to our M17 VU meter, which just wiggles around -20dB most of the time. It's kind of ... just ... Meh. The M17 does a hell of a lot of things at an exceptionally high level. I wish the software visualizations matched the extremely high bar set by the hardware.
May 30, 2022 at 10:47 AM Post #3,994 of 5,690
Dear viffer,
Best regards
@FiiO Thank you for answering.
This needs to happen in your next firmware update.
You can’t have 2 top of the line items that, and although they support HD codecs, they do so with incompatible ones, and can only talk to each other with Lo-FI standard aptX codec.
They should have been HD codec compatible right out of the box!.
May 30, 2022 at 9:30 PM Post #3,996 of 5,690
Does anyone still have the popping or clicking noise issue during playback? I want to pull the trigger on one but this issue might potentially ruin my experience of the M17…
May 31, 2022 at 7:06 AM Post #4,000 of 5,690
Never had this issue.
The popping noise only happens when you first press play (AMPS and DACS come on line) and again if the unit is idling for 24 seconds (AMPS/DACS off line) it does not affect normal play and in fact, the M17 has one of the darkest background I’ve ever heard, the noise is inexistente, she is pretty much silent!
May 31, 2022 at 7:54 AM Post #4,001 of 5,690
To be honest, I never observed it.
I mostly stream Qobuz and I get some random pops when selecting track with different sampling rate but this is probably Qobuz related because it also happens with other devices.
May 31, 2022 at 12:38 PM Post #4,002 of 5,690
Does anyone know if the M17 can be connected to a TV via Bluetooth for watching movies?
May 31, 2022 at 1:04 PM Post #4,003 of 5,690
Yes, but there’s quite a bit of lagging and lip syncing is off . There’s no lagging problems when connecting to an Apple TV box via airplay.
May 31, 2022 at 2:21 PM Post #4,004 of 5,690
I never had it either. Purchased it recently from a recently manufactured shipment delivery.
May 31, 2022 at 3:22 PM Post #4,005 of 5,690
Ok I’ll give that a go, thanks!
