I can't see I have M15, the Fiio music application is globally the same for all fiioThe VU meter is available in the FiiO music app
[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
dsrk
It's there on my M11 Pro too, you just need to tap on the album art in now playing screen.I can't see I have M15, the Fiio music application is globally the same for all fiio
You can see the regress
There were three to choose from on the older models
Now the poor one
Now the poor one
dsrk
Yes, I liked the ones on my X7ii than this one.You can see the regress
Now the poor one
Similar to the McIntosh traverses In fiio x7
This one was great now they don't do that And you just have to bury the old code and free it for the people People like such accessories
Simple menu Cool colors Now a lot of inscriptions, small covers it used to be better
It is there, just click the album art.
@FiiO
The FiiO Music app refuses to play some of my Hi-Res Albums. (All tracks)
USBAPP plays all of them so it is not a corrupted files issue.
Please advise
Also, will there ever be support for the Core Audio File container (.CAF)
In the FiiO Music app?
Please advise
Forgive me if this has already been discussed, but when playing Tidal, specifically MQA files, why does it not display the unfolded rate on the notification bar?
1. Would you mind sharing the one of the file in the certain album to us for check?@FiiO
Please advise
2. We will report to the engineer for assessing about that. And if you are convenient, please share a .CAF file to us as well. Thanks in advanced!
Best regards
According to the latest MQA requirements, the sample rate before MQA compression should be shown (i.e. the source sample rate of the original file). So when playing a MQA track, the status bar and the FiiO Music now playing page will show the source sample rate of the MQA track.Forgive me if this has already been discussed, but when playing Tidal, specifically MQA files, why does it not display the unfolded rate on the notification bar?
Best regards
@FiiO
Of the ones that your app doesn’t play, the smallest Hi-Res WAV file I have is 106MB.
Please let me know how many seconds or minutes of music you need the .CAF file to be and I’ll create one for you. Bear in mind .CAF files are uncompressed and can be very large.
If you could provide me with a link where I can upload them (via private message), I’ll be happy to share them with you for analysis.
For developers information on the .CAF container specifications please Click here.
Reason for edit.
I edited the link as I initially linked a very ligh and easy to digest information of what a .CAF is
This new link deals with in-depth developer information of the Core Audio File container specification which, will be more useful to FiiO.
Reason for edit.
@FiiO
Was not possible to solve the M17 usb output problem with the last firmware update 1.03?
When i connect M17 with usb to your K9 Pro Flagship/Questyle CMA15 etc etc etc,and i play my music (sd card) and skip from one track to the other...there are some dropouts in the beginning from the new track (only in the beginning)
With every other Player (AK/Lotoo/etc etc) no problems with the usb audio output when i connect/pair them on your K9 or different other Dac Amps
My question what is wrong?why takes this so long?
You remember this picture?would be nice that works really
Thanks and greetings from Austria
NOMAX
PS.and last Question.....will be possible to play my music/the tracks from M17 (sd card) with usb output flawless without dropouts
when i pair it to your K9 Pro in the future?
When i play my tracks/my music only on M17 from sd card...works flawless without dropouts
NOMAX
