Change log. Looks iike no MQA for third party apps yet
The following changes and improvements have been made on M11 or M11PRO:
1. Added In-vehicle mode (Settings -> General -> In-vehicle mode, if enabled, the player will power on/off automatically when vehicle engine starts/stops and the FiiO Music app can also switch accordingly);
2. Added manual item sorting for playlists;
3. Added 'screenshot by three-fingers swiping down' function;
4. Added a new play mode: play single once;
5. Added playback position and track remembering;
6. Added a new method to enable volume adjustment by swiping up in FiiO Music Now Playing screen, and also improved the volume bar operation (now you'll need to drag on the volume bar to adjust the volume instead of just tapping as before, so to avoid misoperations);
7. Fixed the issue where the playback would fail in the new version of Amazon Music;
8. Improved the effect of the equalizer and fixed the random equalizer failure issue;
9. Improved the display of the FiiO Music background;
10. Improved the display of the lockscreen album art;
11. Improved the All to DSD function and reduced its power consumption;
12. Miscellaneous bug fixed;
13.M11 Pro: Fixed the issue where the player might power off automatically during audio playback if the power off timer is enabled.
