FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
Nov 26, 2019 at 1:15 PM Post #815 of 1,928
Anyone used this with andros balanced? Get hiss on the normal m11 and looking at this as an option.
I don't have the Andromeda, but with the Empire Ears Phantom I could run them balanced at high gain and did not notice any hiss. The Phantom are not as sensitive as the Andromeda, but I did get hiss with the M11 (be it within acceptable limits for me personally) and so the Pro seems to be cleaner.
Nov 26, 2019 at 3:49 PM Post #817 of 1,928
here is my bug list of m11pro:
- wifi - player cannot connect to my office network, but works well with my home network and shared by my phone. At the same time filo m9 can connect to my office wifi.
- rebooting in USB DAC mode - if bluetooth dac enabled and I try to play track in desktop Tidal client, the player sometime go to reboot
- no reaction when you press the play button - sometimes when the screen turns off the play button stops working so need activate screen again for that
- a couple times the player suddenly stop playing - reboot can fix it
Nov 26, 2019 at 6:39 PM Post #819 of 1,928
Roon updated to 1.7 recently and there's also an update to the mobile app. How long between an app update to when the updated version is available in the FiiO applications section (not using third party Apk market)?
Edit: downloaded from Roon's website, but still curious about the answer (like for Tidal as well).
Nov 27, 2019 at 4:07 AM Post #820 of 1,928
Dear friend,
We have reported to the engineer for updating the apk file in FiiO market. Thanks for your feedback.
Best regards
Nov 27, 2019 at 4:11 AM Post #821 of 1,928
Dear friend,
Is your office Wifi the one need to log in?
And for other issue, you could send the log files to us(support@fiio.com) for check: https://www.fiio.com/newsinfo/239924.html
Best regards
Nov 27, 2019 at 11:32 AM Post #822 of 1,928
Dear friend,
Best regards
Sure, I need to login and specify this params 1). EAP Method: PEAP 2). Phase 2 authentication: MSCHAPV2 3). user/password. At home I just use wpa2 and user/password and it works well. fiio M9 can connect to both networks, m11pro only to the last one.
Nov 29, 2019 at 10:13 AM Post #825 of 1,928
Anyone using Fiio FH5 earphones with Fiio M11 Pro? How the sound quality of this combo.
Here you need to proceed from the genres of music that you prefer to listen to.
I did not listen to FH5 with M11Pro, but I listened to FH5 with M11. The FH5 headphones have a smoothed high-frequency range and therefore listening to music in such genres as Pop, electronica, vocals is comfortable, but I lacked high frequencies on classical works. If you are not a fan of high frequencies, then these headphones with the M11Pro you will like.
