nigel801
- Apr 23, 2009
Does M11 Pro now support MQA, will it also come to M11 via firmware upgrade?
I would recommend taking the Fiio FH5. They have very good sound, powerful low frequencies, expressive mid and pleasant high frequencies. The sound itself is voluminous with a good construction of an imaginary scene, when listening, you get the feeling that you are listening to good full-sized headphones.
What kind of music do you prefer to listen to? (Genres)
Dear friend,Does M11 Pro now support MQA, will it also come to M11 via firmware upgrade?
Last I heard Fiio was having difficulty updating the firmware. When do you expect this to happen?Dear friend,
The MQA is only available on the FiiO Music App, with support for 3rd party apps (e.g. Tidal) coming with a future firmware update.
Best regards
i dont had many over ears , but the shure srh1540 fits this what you are looking forHello dear,
I like to listen to all Genre's. But i will like headphones which are warm, detailed, dynamic with lots of punch, don't like harshness in high's at all.
Fiio FH5 seem good for my taste, but i prefer over ear headphones.
Any recommendations?
Thanks in advance
Weird—this doesn’t happen to me at all. Qobuz on the M11 Pro works great. I just started my trial thanks to the Amazon Music threadanother annoying bug @FiiO
When using Qobuz on M11pro, when one track is finished playing, the next track will have a loud static sound. Doesn't go away if i press FWD. I can only pause it, wait and then play again.
I can confirm this behavior when using All to DSD—it can create a weird swirling high frequency noise. This only happens when streaming from something like Qobuz/Amazon/Primephonic/etc, and does not happen all the time.Dear friend,
Which output are you using? Does the issue you mentioned happen in all you music files?
Best regards
Amazon music works without any tricks on the M11 Pro. It’s the only DAP I have that works properly without fiddling.Anyways, anyone got Amazon Music to work? I remember reading about how it was tricky to get working on M11, do we have to pull the same trick here?
Really? You don’t have to play a hires file before using Amazon Music? I have to do that for Amazon Music HD.
Good news and bad news here.Same here, huh? I have to do the "trick" by playing a FLAC with HiBy first and then start Amazon Music app, sometimes twice, to get it to play at all. It works perfectly after. Are you sure you're running the latest Amazon Music HD version, or just the old non-HD version which does work without the trick but no HD?
Bad news: I upgraded to the newest version yesterday evening, and now I can't stream any files at all. It just spins forever, like on my N6ii.
Yes, exactly. I don’t know if I can revert, I’ll have to check that later.You mean you upgraded the Amazon Music App? Can you go back to the previous one? Can you send the link?
Thanks!
I use APKPure.
