I just have Qobuz open. No other apps open.I mean are you using the Fiio player when you listen to Qobuz
FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
- Thread starter JamesFiiO
- Tags
- fiio fiio m11 pro
Finally receive my device, sounds fantastic! how to test mqa playback? Does anyone have any examples?
Congratulations! What other gear are you using?Finally receive my device, sounds fantastic! how to test mqa playback? Does anyone have any examples?
Fa7 + 4.4D cable
@FiiO
Problem ::: Sony Bluetooth headphone (Model: H900n hear.on) volume too low , using LDAC (toggling on your developer option menu setting 'Disable absolute volume' don't work either) Any other solution?
Please help
Thanks
Please help
Thanks
You have to put the volume on the M11 to 100% and then adjust volume on your BT device. That's how FiiO does BT, don't ask me why.@FiiO
Please help
Thanks
Still have not got the Ali Express case, it's been over a month...
ayang02
Anyone found a good case for the M11 Pro? I looked at the DD case and it seems like the cutout for the 4.4 mm port may not work for certain plugs based on some users’ feedback.
DD case looks very ugly and i didn't see other options
I ordered the m11 case off ebay, and screen protector and i'm happy with it...fits pro perfect...DD case looks very ugly and i didn't see other options
mrs1986
- Feb 22, 2010
I’m looking forward to getting this case, I really like to use a case with my dap!
I ordered the one off Ali Express over a month ago, still don't have it...I’m looking forward to getting this case, I really like to use a case with my dap!
ayang02
I’ve been looking for THIS version of the SK-M11 case as the ports are not blocked at all.
I got a free SK-M11 with my M11 Pro purchase but it look like this and doesn’t work for some 2.5/4.4 mm plugs:
I do find the case hard to remove since it’s designed for the M11 and the Pro is slightly thicker.
MadSounds
- Jan 23, 2015
I ordered the m11 case off ebay, and screen protector and i'm happy with it...fits pro perfect...[/ATTACH]
and your using the screen protector? someone complained about the m11p not coming with one pre-installed and fiio responded saying
I cant see any sign there're a screen protector on, which is really impressive considering it's there. Is it just on the front or the back glass also?of course it has a screen protector which is pre-installed
I ordered my dd case back on 10/24 and it arrived 11/14 without aliexpress's tracking showing any progress. I would not recommend this case as it makes the side button extremely easy to press accidentally. The tight fitting case makes any pressure around the buttons trigger them so you can barely touch that entire side. I've had to disable side buttons while the screen is off to avoid pitching the m11 at the wall when I accidentally hit skip mid track (kidding) . I could defiantly see large connectors being incompatible.
