rlw6534
Thank you, i thought that HWA and LDHC were the same thing
https://www.hwa-audio.org/how-it-works
Damn that's confusing
I thought so also???
Dear joe75,Thank you, i thought that HWA and LDHC were the same thing
I understand now, Thank you for that last detailed answer.Dear joe75,
Can the connection work after enabling the HWA option in FiiO Music app?
The HWA in FiiO Music app is an old version HWA/LHDC.
So it is not same as the LHDC supported in our UTWS5 or some new mobile phones.
Best regards
Reset the database and retried.
Same result.
Recorded a short video of it but my iPad is not letting me upload it to the website.
EDIT Try this link on YouTube
Dear Airsulpture,@FiiO Any update on this ?
That’s a pretty bad UX experienceDear Airsulpture,
The lyric will return to the current playing progress if you slide the lyric while playing music. If you only want to read the lyric, you could pause the music first.
Best regards
Dear friend,That’s a pretty bad UX experience
Perhaps take a look at Poweramp. You can manually scroll while music is playing and the lyrics stay still. It is pretty useless for the lyrics to scroll back to the top while you are reading them. This would be offset if the lyrics scrolled in time with the music but it does not. So the only way of reading them in time with the music is to manually scroll - this is made useless if, as it does, the app resets the lyrics to the top.
The lyrics do NOT a scroll back to the current playing position with embedded lyrics, they scroll back to the beginning hence why I said the UI experience was just about useless. With embedded lyrics there is no scrolling of lyrics in time with the track.Dear friend,
No, the lyric will scroll back to current playing progress after stop scrolling the lyric for some time.
And in your perference, you would need to return the lyric to current playing progress manually if the lyric stay after scrolling. We will report your feedback to the product manager for assessing.
Best regards
Estimado FIO,
Tengo un FIIO M11, quiero actualizar a un FIIO M11 PLUS II o superior.
Mis preguntas son:
1º) Los archivos guardados en la lista de Favoritos, y otros en la PLAYLIST, ¿se pueden transferir a un FIIO M11 PLUS II o superior?
¡Siempre en la misma tarjeta Micro SD!
2º) ¿Qué se puede hacer, si se agota la batería en FIIO M11?
3º) FIIO M11, no muestra los archivos internos para pasar de la MicroSD a PC en W.10, con el cable USB. Probado con FiiO_v5.30.0_2022-02-28_setup y versiones anteriores
Me puedes ayudar. Muchas gracias.
Dear friend,Estimado FIO,
Tengo un FIIO M11, quiero actualizar un FIIO M11 PLUS II o superior.
Mis preguntas hijo:
Dear friend,3º) FIIO M11, no muestra los archivos internos para pasar de la MicroSD a PC en W.10, con el cable USB.
solo sale:
Dispositivos portátiles. FIO M11. Portable Media Player no sale, no abre
