FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
post-15434964
Post #7,546 of 7,645
Kenneth Galang
Toronto
Toronto
Nothing I wrote is untrue, but maybe you should've led with the photo given how unusual it is compared with the more common protector coming off instead of mock someone trying to help you. At least the screen protector kept in one piece. Success!
I didn't mean to make it sound like you were wrong or mock you sorry! I wouldn't start with "if it makes you guys feel any better" if I had a common, or not as bad of a problem. For sure if it was the problem I'd say screen protector, which i hope no one would glue to their device screen to fix O.o
Lucky it ripped off cleanly enough that I could scrape off the adhesive Fiio used and apply some super glue and it looks like it was never an issue:)
Reactions: SoundChoice
post-15435828
Post #7,547 of 7,645
misteral201103
Shanghai, China (originally from UK)
Re. LDAC on the M11
LDAC works fine BUT I wish we had the option for the increased resolution available in later Android versions. My LG V30 has a 'highest quality' option which I think is a sample rate of 96khz (although I think I have something wrong there, sample rate in khz?) Anyway, point being that my V30 has a higher quality through LDAC option resulting in Bluetooth that sounds as good as wired to my ears (and I'm a BT skeptic). Tried BT once on the M11 and it didn't measure up to that high standard, so it's wired all the way for me.
@FiiO if there's any way to have this feature without the impossible jump in Android version, that would be amazing!
post-15438231
Post #7,548 of 7,645
Sven2015
I don't know if Android 7 offers more LDAC options such the qual. / normal mode. With Android 9 I can see more options and in this case variable bit rate for a better transmission.... but it seems, anything is wrong with all M-Models (m7->m11) cause all three models / devices have the same micro gap issues....all three models based on Samsung SoC..... it seems in combination with BT module (Samsung? for all three models, too) and Android 7 the issues occur....
I never had issues like these with other models / devices of other manufact.
It's interesting...
We have three LDAC modes and every mode offers another bitrate for transmission between device -> headphones.
Tested with Sony XM1000M3!
Quality mode:990 kbps -> many, many micro gaps while music playing in all files -> NOT FIXED by FiiO!
Standard mode: 660 kbps -> very often micro gaps but not so much, but I can hear all the gaps -> NOT FIXED by FiiO!
Prior mode: 330 kbps -> not offered by FiiO -> maybe this mode works -> NO support by FiiO!
SBC mode: up to 345 kbps -> this is the ONE and ONLY working mode for BT headphones I tested!
Several Sony Walkman working perfect in all three LDAC modes.
Several tablets working perfect in all three LDAC modes.
Several other chinese DAP devices working perfect in all three LDAC modes
FiiO M7 -> FiiO M11 are NOT working in both LDAC modes, JUST in SBC mode!
This is a warranty issue in all three cases and there was no fixing by FiiO until today! (maybe FiiO cannot fix it cause it's a Samsung issue ^^ ).
post-15441830
Post #7,550 of 7,645
katatonicone1
Poland
Poland
if the battery is dead and you hook it up to a charger. does a light come on or the screen flash to let you know it getting power?
Screen goes on with battery charging animation.
post-15441899
Post #7,553 of 7,645
misteral201103
ok my fiio might be dead then. i got nothing
I'm sure you've done this, but just in case - check with a different cable and a different charger. Fingers crossed for you mate.
post-15441934
Post #7,557 of 7,645
dallas1990
indiana
indiana
Just try with one cable you trust at least 30-40 minutes. Sometimes deadly discharged accumulator needs a lot of time to make it alive.
ok i'll leave it for an hour. i'll also use a low power charger from a amazon tablet.
post-15449325
Post #7,559 of 7,645
Airsculpture
English but living in Fredericton, Canada
Ok again.... Playlist sorting.
sort by filename or first letter, seems to do the same thing. Also not only doing the same thing, but also sorting the contents of the playlists into alphabetical order not just the playlists themselves.
Am I missing something ?
Users Who Are Viewing This Thread (Users: 3, Guests: 15)
