Airsculpture
I'm looking at getting the fiio m11 pro or the new m15. Is it worth it?
Only from what I’ve read and watched, the M15 = No
M11 Pro slight better sound but you lose a SD card slot, for me a deal breaker. YMMV.
so just get another m11 (non pro) and an awesome portable amp?Only from what I’ve read and watched, the M15 = No
ok, i had a m11 normal but it died sadly got refund. and was looking around thanks man i'll get a new one and save the money for the woo audio WA8I have demoed all 3 models, M11, M11 Pro, and M15.
I personally own the normal M11 because although there are slight differences in the sound of each of them, I don't believe it warrants the price gap between the 3.
Unless you are getting a smoking deal on one of the 'higher' models, I would stick with the normal M11.
yea, i was just looking at it cause i got extra money. but after hearing what people said im glad im just sticking to the m11. and i got a thx amp/dac from monoprice love that thing. but if theres one thing i want is a portable tube amp lol. i love my dark voice on my desk. Also if I wasn't so dependent on Spotify and Amazon for music I'd wait and try to get a lotoo paw 6000I have upgraded to M11 Pro from M11 and couldn't be happier. Pitch black background with Noble K10 where the M11 has some hiss. It drives nicely all my cans and I especially love how it pairs with Sony MDR-Z1R and with the good old Oppo PM-3. Balanced port give a run for MojoPoly and then some. Much easier to live with than the Chord combo, too. Can't see any reason to spend twice as much for the M15.
Someone did blind testing recently, comparing M11, M11 Pro, and M15. People were supposed to pick the best player. Most people picked M11 Pro, smaller group picked M15, finally the smallest group picked M11 as the best. That's a bad result for M15 costing close to 3 times more than M11 and twice as much as M11 Pro (while still having only one slot). It also means all of them are quite similar. Thus I think the rational choice is M11, value-wise.
i mostly use my audeze isine 10's for on the go. i do want to get some more iem and portable headphones for sure.I'd say it depends on your headphones/IEMs and music. If both are of a high grade (Andromeda or better for example) and you are listening mainly at home or in another quiet place, then the M11 Pro might be worth it. If you're using stuff on the go where there is a lot of noise then the benefits of having higher quality gear are lost pretty much.
Thanks for checking. I did factory reset and have the latest firmware, but got the same result. Now I am almost certain my unit is faulty with alltodsd. The only strange thing it only happens with tidal, it works flawlessly with fiio app. I updated tidal to the latest with apkpure as well.
Never heard any hiss on M11 but I listen to FLAC and Qobuz. Great pairing with beyerdynamic Amiron Home + their balanced cable. Single-ended was underwhelming for these 300 Ohm headphones.Did you ever resolve this issue? I have the exact same thing happening with my M11. Its only on Tidal. The FiiO app has no noise. The noise sounds like a high frequency hash over the actual music. Its easy to hear it with soft content (i.e. piano, acoustic, etc.)
Get Riva Festival. Have been using it with M11, connected with Audioquest Tower 3m cable (3.5mm to RCA). You can also consider KEF LS50 for more typical stereo (more expensive but great sound)Hi, I have the Fiio M11 and really like it. I would like to get a speaker that I can connect it to via one of the outputs. Bluetooth is nice but I don't want to be limited to just using bluetooth all the time as it eats up the batteries pretty fast.
My budget is £700.
