FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
456 457 458 459 460 461 462 463 464 465
467 468 469 470 471 472 473 474 475 476
  1. jdtenny
    Are you sure the speaker is ready to accept pairing? Is your bluetooth on (on the M11)? Can you see the device, but just not pair with it? If you can see it, tap on it in the settings->bluetooth-><speaker-name> dialog. Try turning the M11 bluetooth on and off again if necessary.
    If you're savvy about all the above and have it set up, then my best guess is that some _other_ device is actively paired with the bluetooth speaker (your phone maybe?) and needs to disconnect before the speaker will accept a new connection.
    I've never had trouble pairing with bluetooth receivers. The most frequent problem I have is when some other device is paired with the target.
  2. Ulrich B.
    Hello,
    BT-Devices works great on my M11.
    Two BT-Over Ear Headphones and one BT-Speaker...
    Greetings
  3. Airsculpture
    I really like Poweramp.
    IMHO the FiiO music app lacks punch when using the EQ and it doesn't recognize embedded lyrics, plus some of the scrolling is not as smooth as Poweramp.
    HiBy player is a little jerky in the UX but the EQ is slightly better than the FiiO app.
    Anyone using a nicer player for both UI/UX as well as EQ ?
    SoundChoice likes this.
  4. JLW654
    Fiio music equaliser on mine "sticks" off, weirdly won't kick in until I move a slider, then it works. Switch off and switch off unit and next time it's gone to sleep again..??
  5. oHOWEo
    I have a question for you @FiiO
    My samsung Galaxy s9 is able to output via usb otg to my Arcam Dac and charge at the same time using a usb-c otg dongle with PD (power delivery) the Fiio M11 will only do one at a time which affects it's ability to become a great transport. If I plug power in first it will charge but not output to Arcam, if I connect usb to arcam first it will play but not charge.
    Is this a hardware limitation or can it be supported by software update?
    It would be a major plus if you could use it as transport and not have to rely on battery power.
    This it the adapter https://www.amazon.co.uk/UGREEN-Aluminum-Pass-Through-Thunderbolt-Compatible/dp/B077FSBGQK
  6. JLW654
    Got the Fiio case, it's a lot better than I expected, pleased with it.
  7. MachBot
    @FiiO Posible to look into this?
  8. MichaelOH
    Has anyone else noticed that the beginning of hi-res audio tracks are slightly cut-off? Listening to an ISO/SACD of Bob Dylan's "Oh Mercy" right now, and all of the beginnings of songs sort of jerk to start, like "we now join our regularly scheduled program already in progess!
    I've also noticed this with just hi-res FLAC files as well.
  9. exitfire401
    Not having that problem at all with any format in both hiby or fiio
  10. Richter Di
    Nope. Not a problem.
    Qobuz and Amazon Music remain an issue which makes me almost regret to have bought the M11.
  11. Simple Man
    With my M11 I noticed the same problem, specially in HR Qobuz and HR from the NAS.
    Last weeks it seems fine, way better. Don’t know why or how.
  12. claudiuschan
    Anyone interested in used condition m11 ? I plan to sell mine. Plan to upgrade to m11pro.
  13. Simple Man
  14. atahanuz
    I had a DX220, I installed Fiio Music App on it but the app and the remote control by my phone was extremely laggy.
    How fluid is the Fiio Music App on M11 (PRO) when controlled by a smartphone?
  15. oHOWEo
    The problem with mine is 5ghz, 2.4ghz works ok
