FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
454 455 456 457 458 459 460 461 462 463
465 466 467 468 469 470 471 472 473 474
  1. brainchill
    I've heard this with this particular album on other daps as well ... definitely not that weird.
  2. salla45
    Could be the equaliser's on in the fiio app and causing clipping?
    I'm listening now via Mojo and FH7's and getting no distortion. The mastering on my copy at least is excellent. Getting DR of 13. Just look at that lovely curve...
  3. FiiO
    Dear friend,
    Could you please share the files to support@fiio.com for us to check?
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  4. oHOWEo
    Hello, doe's anyone have any Wifi issues with their M11? mine seems to cut in and out.
  5. exitfire401
    No problems with mine, though I'm in a fairly small apartment when I'm on WiFi.
  6. fatmanny
    No issues here. I even have mine connected at University.
  7. Chaz1952
    What is the default FILTER setting on the M11? Switching between them and forgot how it was set at factory. Thanks!
  8. jdtenny
    No problems with the M11 WIFI. However between the high bandwidth requirements of my TIDAL habit, and the fact that, unlike netflix, my wife isn't listening to the music with me, when she's cooking downstairs the microwave oven definitely can interrupt the wifi enough to spoil TIDAL streaming. Until I used the M11+Tidal I had never noticed microwave problems. It's totally on point too. Turn off the microwave, tidal resumes. Turn on the microwave, tidal likely to miss and stall.
  9. exitfire401
    Short Delay, Sharp Roll-Off
    SoundChoice and Chaz1952 like this.
  10. Chaz1952
    Thanks!
  11. Sonic Defender Contributor
    What a shame that album is, I have been following Tool since the 1990s and this album I have to say sounds like Lateralus 2.0 (but not anywhere near as good, Lateralus is brilliant). It feels like it took 13 years to force out what a shame, I feel bad that as artists they clearly felt that they had to put out another album. Oh well, parts of it will grow on me.
  12. FiiO
    Dear friend,
    Did you try another Wifi or do a factory restore to see if it helps?
    Best regards
  13. oHOWEo
    Hello
    Yes non of that fixes the problem, I get check internet connection on Tidal app, I have to reboot M11 to get it working again. When I wake the screen oftentimes the wifi symbom on M11 is empty, when it's connected its full signal. When I run speedtest it shows 40mbs, all my other devices, phone/tablet/laptop show 200mbs on 5ghz.
  14. gLer
    The M11 doesn’t have the strongest Wi-Fi antennas. Most DAPs don’t. Don’t expect smartphone/laptop-level Wi-Fi strength.
  15. oHOWEo
    It should work in the same room as my router though?
