loungecat
Hi WianHi,can M11 recongize your SD card correctly now?If yes,just insert it in M11 and ingore the format notification(1.0.2 has blocked the notification of this selection),you don't need to format it to use.
If your SD card can't recognized correctly,may be you can format it by computer,and then insert in M11 to use.
Tidal wont recognize an SD card so I don't think the player will either.
I will try and format the card on my PC first and then try again.
Also it must see the card Initially as it tries to format but just fails
