RikudouGoku
Member of the Trade: RikuBuds
1. Test the trial first if you like it go to step 2.How do I get and install neutron ?
2. Go to their website: http://neutronmp.com/buy.html :
Android: Directly from the developer via PayPro3
3. Pay and use mail that you will sign in with ( I used Gmail since it is my main mail)
4. Download: http://neutronmp.com/downloads/category/1-generic-android.html, chose NeutronMP_ARM64.apk
5. Install app
6. Before you login, you need to disable 2 step authenticator from your gmail and activate lesser secure apps. : https://support.google.com/accounts/answer/185839?co=GENIE.Platform=Desktop&hl=en , https://support.google.com/accounts/answer/6010255?hl=en
7. and activate Pop in gmail. : https://support.google.com/mail/answer/7104828?hl=en
8. sign in neutron, settings, help, account. Server: pop3s://pop.gmail.com Username: #####@gmail.com Password: #####
9. It should turn white, and you are ready to go. If yellow something is wrong.
10. if you have activated neutron you can revert all the gmail settings you had to change.
