RikudouGoku
Member of the Trade: RikuBuds
Does anyone have tips for nice apps for the m11? My recommendation is zedge wallpaper app.
You can if you select the 3dot menu and choose show system than go down to luancher3 ?
If you're in apps>settings and tap the three dots on the top right, select "Show System" and the launcher will show. Then you can clear cache by tapping storage once you're in the app menu.
Ok
Did a few scans last night and finally up to my estimated and expected 32391 track total
I have download the APKPure download that was available
What would you recommend in downloading music app wise and how does one do that and install ? Device and Android newbie
Yep as long as both the radio antennas are off.Yup only lost 3% in last 8 hours here, no bluetooth or wifi on.
Juj
Nova Launcher is a must for me. Solid Explorer is nicer than ES (you can’t uninstall ES but you can hide it with Nova). Plex is essential to how I use it, Tidal too. I have Netflix loaded but don’t really bother using it. And Sophos Mobile is great if you plan to experiment with not-so-Kosher app downloads. Nothing else I can think of off hand.Does anyone have tips for nice apps for the m11? My recommendation is zedge wallpaper app.
Ok
Yes it does, it’s what I ended up using per card as the scan timed out a couple of timesI don't have a M11 yet, still undecided as I can't yet justify cost.
I have been following your issue.
I have the Fiio app on my phone and one of options is to "scan selected folder(s), so does this option not appear on the M11?
It allows me to scan separate folders containing Flac, DVD-Audio rips and sorry to say it mp3s.
UI and UI performance a step up from my old Opus #1 with a lot smaller load time for Album Artwork
But how do Apple and others do it so there is zero, I repeat zero, load times for Album Artwork ? Clearly it is possible.
Sound wise I’m loving the clarity. EQ doesnt seem to make much difference? Yes I have it switched on lol
I haven’t changed any filters
Bit disappointed embedded lyrics don’t show up but that was half expected and no biggy
Even on my budget Sennheisers the sound is really nice
How do I get and install neutron ?
I don't think there is but it's pretty simple.
1. Buy directly from their site
2. Wait for email
3. Use link in the email to download the app
4. Download APKPure from the Fiio app store
5. Move the Neutron app to any of your folders inside Fiio?? I moved mine to downloads
6. Install Neutron thru APKPure
7. Use registered mail to activate
