I have something similar. Would like to be able to edit tags on the M11 directly. I'll probably end up using my desktops, though, if nothing good (or not wildly suspect!) comes up.
James - can you please provide more info?
For starts, when will it be released? The main reason for me to buy M11 is to use as source to my desktop DAC / amp... DK1K (if done right) would be the perfect solution!!
I'm a happy owner of M11 now. I have a question about charging. In the quick start gide it is mentioned that is recommended to use QC 2.0 compatible charger. Is it ok if I charge it with my ipad charger which is not QC 2.0 compatible? Will this affect battery life-span?
Another question: which digital filter is preferable? Never understood the differences between those and barely hear a difference.
A regular type C charger will do. It will charge longer vs a fast charger but I find that "slow" chargers usually provide better battery life (longer usage).
I was originally going to get a topping dx3 for my first amp/dac but currently leaning towards the M11 as it is able to drive almost anything. Unlike most users here, I will be mostly using offline Spotify and tidal
Thank you. Any plan to introduce an accessory like the DK1 dock for the M11 ?
I would like to use M11 to replace my PC as transport / source into my desktop DAC / Amp setup!
Attention Fiio: The M11 costs 499 Euro here in Germany. With a suggested USA retail price of 449$ this is unacceptable. I was very interested in the unit but at that pricepoint i wont be getting one. Please tell your distributors to stop beeing bloodsuckers.
As other users mentioned to you, there are higher taxes in some Europe countries. So the price may be different in different countries. Thanks for understanding.
Yes, it will be better to charge it to 100% first and we will also design a new DK1K so you can plug the M11 into the dock and use a extra 5V adapter .
So what upcoming DAPs are confirmed to release? If I'm correct we'll be getting an M11 Pro and M15, but will there be an M13? Any idea about when they might be announced?
