I thought about that... 2 problems: 1. Many / most of them are kind of wedge shaped, and the M11 would just sit there unsecured. so... good as a prop for watching youtube videos, but not when you keep touching the screen running the risk of M11 just fall off. 2. The one that do have clamps or other mechanism for securing the device - have a thickness limitation (usually 13-14mm) which is fine for phones, but not for M11 (15.5mm before adding a case)! Still, if I find one that does hold the thicker M11 securely - that could be a reasonable solution. Did not give up looking......
the holder is from amazon and fits m11 nicely https://www.amazon.com/gp/product/B00C7J5ZC0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 its mounted to a small piece of Corian countertop material but could be anything. added some rubber feet and a few holes to run power and audio cable
@FiiO the music app won't let me delete any files. I get a notification saying "Not supported in this version."
@fatmanny have to tried to delete the files when the M11 is connected to your pc? Using windows explorer Juj
Yes I have. That works fine. I just thought it would be easier if I can delete duplicates on the device
I'm sorry cant help you there buddy. I do all my library managment via musicbee first before I add any music to the M11 Juj
