Well, Im using headphones, TH900. The N6II seems to really push the TH900 very well. The amp I use is more than adding power. It can control the frequency of the bass. I can make it push only the sub bass region of the bass. This helps when Im on the go to keep outside noise grom coming in.
Being new to DAPS I cant figure out what bulk management setting does on the M11 in Fiio music player? Im primarily interested in random play where tracks play from different albums on the card.Should I keep bulk management on when I use random play? Im also a bit confused on what happens when you choose play through folders setting? Thanks for your help
After turning on the 'play through folder' function, the playback will still continue when finish playing the music files in current folders or album.
If you would prefer shuffle play the music files from different albums, you may add the albums to a playlist and shuffle play the songs in the playlist for help?
Page 20 4. Function menu Tap the shortcuts icon of function menu, the following functions can be performed.Selected sort order: sort by added time, sort by first letter, sort by filename.Bulk management: batched playback, batched adds to my favorite, batched add to playlist, batched delete, exit batch operation.
I transferred some music to the sd card whilst the player was connected to the comp but after scanning they didn't show up in the library. Is there a way to do this without having to remove the sd card everytime?
I had to fiddle about to get the file transfer menu up, but then the music didn't show after a scan. First time tried this as just popped my card in straight from my other player.
Could it be due to file structure, I had issues like this with other devices after just switching and found best to sometimes format the sd and start a fresh. I know its a bit brutish but you know what they say "brute force and ignorance"
